Question about Garmin nuvi 205W GPS Receiver
How do I access the manual for this product? The
How do I access the manual for this product? The sound is off...how do I turn it back on?
    President:
  • 1,514 Answers
The manual is available in Adobe Reader format from http://www8.garmin.com/manuals/2675_OwnersManual.pdf. To get the sound working:
1. Press the Volume (Speaker symbol) in the bottom right corner and check that the mute box is not ticked. If it is press it and it will be ok. Also check that the volume isn't fully down.
If that doesn't solve the problem it may be because the voice file is not selected or has become corrupted.
2. Press Tools, then press Settings (or Locale on som models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
3. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 2 above.
Posted on Sep 10, 2010
  • graham7050 Sep 10, 2010
    Thank you for answering my questions.
    I have the sound back on.
    Re Manual.....have difficulty understanding why when a product
    is purchased that the online manuals have a price tag.
    I realize that they do cost to be printed but a basic manual for this product
    - free- would be very helpful for information regarding the use of it
    Thanks again for your information.
Need to find manual for auvio premium satellite/cable remote.
If you can access this site, I am pretty sure you can get anywhere in the cyberworld without any problem. Why don't you do a search on the Company that manufactured the product you bought or just the product name + manual ( auvio 15-304 remote control manual). You will have several options to obtain the manual - usually free.
Oct 27, 2015 | Televison & Video
Hp psc 500 message "cartridge carriage blocked. Close latches over print catridges, then turn power off and on"
Normally the cause of these errors is apiece of paper or other material in the paper path. Sometimes the paperfeed assembly has become unsynchronized. Use the following steps tocorrect these issues:
  1. With the all-in-one turned on and ready, open the ink-cartridge accessdoor. The ink cartridges come to an access point if the carriage canmove.
  2. Unplug the black power cord from the back of the product. The powerplug must be pulled out to resynchronize the paper feed and carriagemotors. Simply turning the product off does not work.
  3. Remove both ink cartridges and lower the ink cartridge latches, asshown in the figure below, so that they do not catch on the productframe when the product reinitializes. Do not close the ink-cartridge access door at this time. Figure 1: Lowering the ink cartridge latching levers c00169359.jpg
  4. Remove the remaining print media from the paper supply tray. Discard any pieces of media that are damaged.
  5. Unlock and remove the rear access door. Figure 2: Removing the rear access door c00169360.jpg
  6. Being very careful, slowly and gently pull any jammed media out of the product through the rear access door.
    NOTE: Do not pull the media out from the front of the all-in-one product, ifat all possible. Pulling the paper out from the front causes the blackpaper pushers that are located between front rollers to rotate upwardsand block the print carriage. This results in a carriage jam when theall-in-one product is restarted. If this occurs, unplug the all-in-onepower cord from the back of the product, wait about five seconds, andthen reinsert. This forces the product to reinitialize the paper-pickmechanism.
  7. Make sure that no jammed media remains in the product. Be sure to checkinside of the product on the sides to verify that media did crumpleinto these areas.
  8. Reinsert and lock the rear access door. Make sure that the door locksfully. The paper can skew if the rear access door is not fully locked.
  9. Close the ink-cartridge access door.
  10. Plug the power cord into the back of the product. If the product doesnot automatically turn on, press ON. Let the product initialize until afront panel message appears, requesting ink cartridges. If the carriagecannot move, remove the power cable again and determine what thecarriage is caught on. Manually move the carriage to free it fromwhatever has blocked, it and then repeat this step.
  11. Open the product and reinsert the ink cartridges.
  12. Reload the input tray with print media and try printing again. Themedia must be loaded properly for it to feed correctly. It must befully inserted into the product but not to the point that it bows fromthe pressure.
  13. The HP all-in-one product will request that an alignment be performedafter closing the ink-cartridge access door. Perform the alignment. TheHP all-in-one product should be fully functional when the alignment iscomplete. It might be necessary to repeat the process more than once ifthe product was completely out of synchronization.
Clean the paper rollers If the issue persists after checking the paper path and resetting the all-in-one product, follow these steps:
  1. With the product on, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move.
  2. Unplug the black power cord from the back of the product. With thepower cord unplugged, the print carriage (the part that the inkcartridges are in) can be moved.
  3. Locate the four small, metal paper rollers (not the rubber rollers) andthe carriage rod as shown in the figure below. The carriage rod is thelarge metal rod that the print carriage rides on. If these rods are notbright and shiny or if they have buildup on them, they should becleaned. Figure 3: Locating the carriage rod and four metal rollers c00169361.jpg
  4. Use a soft, lint-free cloth lightly moistened with water (distilledwater preferred) to clean the rollers and the carriage rod. With thepower cord unplugged, print carriage should move back and forth freelyso that all parts can be cleaned.
  5. Open the rear access door. Use a soft, lint-free cloth lightlymoistened with water (distilled water preferred) to clean the threerollers that are shown in the figure below. Close the rear access doorwhen the cleaning is finished. Figure 4: The three paper feed rollers c00169362.jpg
  6. Close the all-in-one product and reconnect the power cord. Try printing again to see if the issue is corrected.0baee9e.jpgc4134e9.jpgd4b3194.jpgbe80789.jpg
Oct 22, 2008 | HP PSC 500 All-In-One Printer
The check paper light is flashing, have paper checked for blockages and turned off and on but will still not print or copy. Will not take the paper in
  • Use the On button to turn the product off and then disconnect the power cord from the back of the product.
  • Press in the tab on the left side of the rear access door, remove the rear access door, remove any jammed paper from the rear paper rollers, and then replace the rear door.
  • Open the print cartridge access door, remove any jammed paper from the front paper rollers, and then close the print cartridge access door.
  • Connect the power cord to the back of the product, use the On button to turn the product on, and then try printing again.
  • Jul 02, 2011 | HP PSC 1315 All-In-One InkJet Printer
    Cartridge Carrier is Blocked
    Check the all-in-one product for paper jams and reset the paper feed motors.
    Normally the cause of these errors is a piece of paper or other material in the paper path. Sometimes the paper feed assembly has become unsynchronized. Use the following steps to correct these issues:
    1: With the all-in-one turned on and ready, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move.
    2: Unplug the black power cord from the back of the product. The power plug must be pulled out to resynchronize the paper feed and carriage motors. Simply turning the product off does not work.
    3. Remove both ink cartridges and lower the ink cartridge latches, as shown in the figure below, so that they do not catch on the product frame when the product reinitializes. Do not close the ink-cartridge access door at this time.
    4: Remove the remaining print media from the paper supply tray. Discard any pieces of media that are damaged.
    7: Make sure that no jammed media remains in the product. Be sure to check inside of the product on the sides to verify that media did crumple into these areas.
    8: Reinsert and lock the rear access door. Make sure that the door locks fully. The paper can skew if the rear access door is not fully locked.
    9. Close the ink-cartridge access door. 10. Plug the power cord into the back of the product. If the product does not automatically turn on, press ON. Let the product initialize until a front panel message appears, requesting ink cartridges. If the carriage cannot move, remove the power cable again and determine what the carriage is caught on. Manually move the carriage to free it from whatever has blocked, it and then repeat this step. 11: Open the product and reinsert the ink cartridges. 12. Reload the input tray with print media and try printing again. The media must be loaded properly for it to feed correctly. It must be fully inserted into the product but not to the point that it bows from the pressure. 13. The HP all-in-one product will request that an alignment be performed after closing the ink-cartridge access door. Perform the alignment. The HP all-in-one product should be fully functional when the alignment is complete. It might be necessary to repeat the process more than once if the product was completely out of synchronization. Clean the paper rollers If the issue persists after checking the paper path and resetting the all-in-one product, follow these steps: 1. With the product on, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move. 2. Unplug the black power cord from the back of the product. With the power cord unplugged, the print carriage (the part that the ink cartridges are in) can be moved. 3. Locate the four small, metal paper rollers (not the rubber rollers) and the carriage rod as shown in the figure below. The carriage rod is the large metal rod that the print carriage rides on. If these rods are not bright and shiny or if they have buildup on them, they should be cleaned. 4. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the rollers and the carriage rod. With the power cord unplugged, print carriage should move back and forth freely so that all parts can be cleaned 5. Open the rear access door. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the three rollers that are shown in the figure below. Close the rear access door when the cleaning is finished. 6. Close the all-in-one product and reconnect the power cord. Try printing again to see if the issue is corrected Hope this should fix the problem Good luck.............
    Aug 02, 2010 | HP OfficeJet Pro 1170c InkJet Printer
    Can't get paper jam out of computer
    Here is the HP website for your Photosmart D5069 printer. Here is what they recommend:
    IssuePaper is jammed in the product. SolutionFollow these steps to clear the paper jam from the product. Step one: Remove any loose paper Remove all loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the printer
    1. Press the power button (c01628209.gif ) to turn off the product, and then unplug it.
    2. Remove the rear access door. Figure 1: Removing the rear access doorc00439062.gif
    3. Gently remove the jammed paper from the product.
    4. Replace the rear access door.
    5. Plug in the product, and then press the power button (c01628209.gif ) to turn it on.
    6. Try the print job again.
    • If the print job prints successfully, you do not need to continue troubleshooting.
    • If the issue persists, proceed to the next step.
    Step three: Make sure that the carriage moves freely
    1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. Allow it to move to that position.
    2. Without turning off the product, disconnect the power cord from the back of the product. WARNING: In the following steps, you move the parts by hand. If the power plug is not unplugged, there is a risk of an electrical shock.
    3. Disconnect the power cord from the wall outlet.
    4. Look in through the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and have not come loose.
    5. Check for any obstructions under or around the carriage that prevent it from moving.
    6. Make sure that the carriage can move freely across the width of the product by firmly pushing the carriage to the left and then to the right. Clear any obstructions.
      NOTE: You might have to reach through the output paper tray to access the carriage.
    7. Close the cartridge access door.
    8. Reconnect the power cord to the back of the product.
    9. Reconnect the power cord to the wall outlet.
    10. Press the power button (c01628209.gif ) to turn on the product.
    11. Try the print job again.
    • If the issue is not resolved, proceed to the next step.
    Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Hope this helps.
    Good Luck
    Feb 22, 2010 | HP Photosmart D5069 InkJet Printer
    Printer carriage stall/stuck
    1. follow the steps below
    2. Reconnect the power cord to the back of the product.
    3. Press the Power button ( ) to turn on the product.
    4. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position
  • With the product turned on, disconnect the power cord from the back of the product.
  • Unplug the power cord from the power source or electrical outlet.
  • Check for any paper or objects that might be stopping the carriage. CAUTION: If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove any loose paper or obstructions found.
  • Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  • Close the carriage access door.
  • Reconnect the power cord to the product and to the power source.
  • Reconnect the USB cable to the product.
  • Load plain paper in the tray.
  • Dec 19, 2009 | HP Office Equipment & Supplies
    Need instructions to replace the "carriage assembly" for ink cartridges on a HP 7400 OfficeJet All-In-One series printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, you can unsnap carriage by pry back tabs or remove screws, depending on the model.
    4. Make sure the print carriage is loose and can move freely. You can then remove the carriage.
      You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    Oct 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Print cartridge carriage is stalled
    There are a few steps to follow to check the Printer.
    Step one: Turn the All-in-One off and on again
    1. Press the On button to turn the product off.
    2. Press the On button again to turn the product on.
    If the error message is not resolved, continue to the next step. Step two: Clear any paper jam Follow these instructions to clear a paper jam. CAUTION: All paper jams must be removed from the back of the product through the rear access door. Pulling the paper from the front of the product rotates the paper feed roller in the wrong direction and can damage the product.
    1. Turn off the product and unplug the power cord.
    2. Turn the product around to access the back of the product.
    3. Open the rear access door:
      1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
      2. As the door shifts to the right, pull the door out slightly to release.
      3. When the door is released, gently remove the door by sliding the door out and to the left.
    1. From the rear access opening, gently pull the jammed paper out of the rollers.
    NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
    1. Replace the rear access door:
    2. Insert the two posts on the right of the door into the holes on the right side of the opening.
    3. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    4. As the door shifts to the right, push in the left side of the door to lock it into position.
    5. Reconnect the power cord and turn the product on.
    Step three: Make sure that the print carriage can move freely Follow these instructions to make sure the print carriage can move freely.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
    If the error message is not resolved, continue to the next step. Step four: Remove the print cartridges Improper placement or installation of the print cartridges can cause a carriage stall error condition. Follow these instructions to remove the print cartridges.
    1. Make sure the printer is turned on.
    2. Open the print cartridge access door, and then wait until the print carriage is idle and silent.
    Press down lightly on the end of each print cartridge to release it.
    • The tri-color print cartridge is on the left.
    • The black or photo print cartridge is on the right.
    Slide both cartridges out and place them on a clean sheet of paper. CAUTION: Do not touch the ink nozzles or copper-colored contacts. Touching these parts could result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    1. Disconnect the power cord.
    2. Move the carriage all the way to the left with your hand.
    3. Close the print cartridge access door.
    4. Reconnect the power cord.
    5. Turn the product on, if necessary.
    6. If the error message is resolved, the placement of the print cartridges caused the problem. Complete Step five: Reinstall the print cartridges. There is no need to complete any steps after Step five.
    If the error message is not resolved, complete Step five: Reinstall the print cartridges, and then continue with the subsequent steps. Step five: Reinstall the print cartridges step 6, Partial reset Follow these instructions to perform a partial reset of the product.
    1. Turn the product off by pressing the On button.
    2. Unplug the power cord from the back of the product.
    3. Plug the power cord back into the product.
    4. Turn the product on by pressing the On button
    1. Load letter, A4, or legal unused plain white paper into the paper tray.
    2. Press the Setup button until Print Report appears, and then press the OK button. Self-Test Report appears on the control panel display.
    3. Press the OK button. The product prints a self-test report.
    Hopefully fixing the problem for you
    Regards
    Richard.
    Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
    I cant reach the paper that is jamed what do i do
    Have you been able to take the door off at the rear?
    If you haven't tried this before, there is usually a door at the rear of the printer, with two circular recesses. Push the latches in and lift the door out, then see if you can reach some or all of your stuck paper.
    Nov 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Noise
    Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
    Most dehumidifiers have access to the fan through the front.
    Below is a link to download pdf.format user's manuals. You must register to access the information, (free). You will need the information off the product data tag, then enter:
    Type of product
    Brand Name
    Model Number
    http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?product.productName=Washer+-+clothes&product.brandName=maytag&product.modelNumber=mah3000ayw
    If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 11, 2008 | Kenmore 54701 Dehumidifier
    Garmin nuvi 205W GPS Receiver Logo
    152 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
