Question about HP Jetdirect 170x Print Server
We use HP JetDirect 170x hubs for several of our networked printers. We have major problems when there is a power outage - all of the JetDirects have to be power cycled in order to start working again. Is there a remote method of cycling them off & back on? All are on static IP addresses. Also, is there anything proactively that we can be doing to keep this from happening?
5 Suggested Answers
crapiemael
  • 241 Answers
SOURCE: This HP printer fails to start on my home network
Printer MUST BE ON before computer is power up so Windows XP can find the printer when booting.
Posted on Aug 03, 2009
SOURCE: How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
Posted on Aug 14, 2009
  • 54 Answers
SOURCE: how to change the ip
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
Posted on May 04, 2011
Hi, Check the manual which has been provided with the product. In order to find a computer's modem IP address provided by a ISP, you can visit http://www.ip-details.com/
Posted on Jul 26, 2012
How do I set up an HP JetDirect 170X Print Server with Windows 8.1 Operating System?
Connect the printer to the print server. Push the test button on the test button on the print server. Two pages will print. One of the pages will contain the IP address for the print server. Connect the print server to the router. Now you need to go to the Control Panel and select "Devices and Printers". Select "Add a Printer". When it searches for a printer, select "The printer I want isn't listed". Next, select "Add a printer using TCP/IP address or hostname" and click "Next". Now, enter the IP address from the test print and click next. That will do it.
May 28, 2014 | HP Jetdirect 170x Print Server
How do i configure my jetdirect 170x
What OS are you using? I had a problem getting the print server to work with Windows 8.1. This is what I found to work: Find the IP address for the printer/server by pushing the "test" button on the print server. "Add a printer" in "Devices and Printers" under Control Panel. Select " The printer that I want wasn't listed", then select "Add a printer using TCP/IP address or hostname". Enter the IP address in the next window and carry on.
I hope this helps. If this is not your problem, you'll need to provide more details about what it is that you need from the print server.
Jan 17, 2014 | HP Jetdirect 170x Print Server
How to specify a host name for jetdirect 170x
Connect the print server to the router with an ethernet cable and connect the server to the printer. Find the IP address for the printer/server by pushing the "test" button on the print server. The IP address will be listed on the paper printed during the test.
Nov 12, 2013 | HP Jetdirect 170x Print Server
How to change the ip address of a hp jetdirect 170X
May 04, 2011 | HP Jetdirect 170x Print Server
page 5-64
Aug 11, 2009 | HP Jetdirect 170x Print Server
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
Jun 05, 2009 | HP Jetdirect 170x Print Server
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
Hp laserjet 2300n
Does this printer also have a parallel and/or USB port? If so, try printing to it via one of those methods to see if the printer itself is functioning.
I've seen this before with a 2200dn where the JetDirect box stopped responding, thus rendering the network side of it inoperable. If you have more of these printers it might be worth switching JetDirect boxes (if they're removable, as on the 2200dn) to see if that isolates the problem to a specific part of the printer (remembering the IP address stays with the JetDirect; not the printer!)
IIRC, replacement JetDirects for these printers are becoming hard to find, and expensive.
Jan 02, 2008 | HP LaserJet 2300N Printer
HP Jetdirect 170x Print Server Logo
82 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
