Question about Kenmore Sewing Machines
Kenmore sewing machine 385.1950281 Serial 71017412. I need the plastic cover for the metal bobbin cover plate number 823005.
    Genius:
  • 1,788 Answers
Try sewingpartsonline.com and it is $5.99
Posted on Sep 09, 2010
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Jun 23, 2016 | Kenmore Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
How do I load the bobbin?
Hello, if your bobbin has a logo on it that looks like a 'H' this has to face up, you then need to take the tread and wind around a metal latch at the bottom the bobbin case then back onto the plastic plate, then place the plastic cover over it. This should then work.
Hope this helps
Apr 30, 2011 | Husqvarna Viking 1
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Bobbin cover plate
click this link directly.http://www.euro-pro.com/europro/categorybrowse.aspx?cat=Sewing(EuroPro) ------------- this is direct link for the service center.you will have to enter the model number and place the order.this will help you.
Sep 16, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Lost the clear cover that snaps over the bobbin
hello it is called the hook cover plate. go to kenmore .com check accessories
Mar 06, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
