Question about Plumbing
I have an exquisite kitchen faucet single lever handle with pull out spout chrome finish #950 10503CP. I need to replace just the spray handle. Where can I find one?
  • 20 Answers
Contact Ferguson Enterprises if there is one in your area. They have the resources from many manufacturers for plumbing supplies.
Posted on Sep 16, 2010
How to tighten swivel spout of moen kitchen faucet
pop the cover off the top of the spout tighten the screw underneath and replace the cap.
May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
Leaking pull out spout
Usually, it is caused by a worn out o-ring.
Jan 31, 2014 | Danze D403412 Melrose Single Handle...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I do not know how to remove the spout from a Delta single handle kitchen faucet. After I remove the handle and inner ball I cannot get the faucet to lift off. Thank you.
You shouldn't have to remove the ball to take the spout off. It simply slides onto the post. Simply rotate it back and forth while raising it up, it should slide off directly towards the ceiling.
Nov 15, 2009 | Delta 2402 Classic Single Handle Kitchen...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
