Question about Remington Health & Beauty
I have an eleltric shaver, {FS790} that was purchased only in July and the cuter assembly is aso loose that I can,t get a good shave. Also the plastic protecter for the cuter assembly flotes all over the place. How is this corrected?
  • jjdoyle_max Sep 11, 2010
    in answer to your ? no it shaved well untill the day I asked for help. the plastic protector never fit well.
    President:
  • 2,777 Answers
I can help you with this issue, but first let me clarify a bit. Has it been like this since you first received the unit? Was it shaving much better at the beginning?
Thanks, please let me know and I can help you further.
Posted on Sep 09, 2010
  • Tim Grayson
    Tim Grayson Sep 12, 2010
    Strange, well there are definitely a few things going on with your shaver that shouldn't be, and there is really no way to adjust the case. It sounds like this unit has some serious issues, and definitely falls under the warranty replacement conditions. I wouldn't try adjusting the cutter assembly as this will void the warranty. I recommend you contact Remington and arrange for an RMA (no cost) replacement. You can contact them at 1-800-736-4648.
    Also, when you call, just so you know, it is actually model number F5790
    Thanks
    Tim
  • shaveroutlet.com
    shaveroutlet.com Oct 21, 2010
    Every time I have seen this problem, it was because of a build-up of hair particles on the top of the shaver body. This build-up makes it impossible for the foil to be locked down into place. The design of this shaver makes it more prone to this than older models.
    The solution is to remove the foils and cutters and then thoroughly clean the top of the shaver body. You may even need to use a toothpick or similar object to clean the build-up in the corners. Once you get it thoroughly cleaned out, the foil will snap firmly into place
How to shave your neck with electric shavers
I find going in circles and diagonals against the grain is best.
Aug 16, 2014 | Philips Norelco 8175XL Electric Shaver
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
Need instructions for changing Arcitec razor head
You look at Manual Norelco Arcitec Electric Shaver.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
And you need to Norelco Arcitec Electric Shaver replacement heads is Norelco RQ10 shaving heads.
Nov 20, 2010 | Norelco Arcitec Electric Shaver -...
Cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 29, 2010 | Braun 360° Complete Electric Shaver
Norelco Spectra 8 Model 8894XL: Need a new Razor Head Assembly
It sounds like you need a new "head holder". These often wear out over time and fall apart. You will find a replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-spectra-sensotec-head-frame-with-hinge-p-329.html
Feb 03, 2010 | Norelco Health & Beauty
Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Norelco Replacement Razor Heads for ...
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Jul 08, 2009 | Remington R510 Electric Shaver
Health & Beauty Logo
191 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
