Question about Gaggia Titanium Espresso Machine
I can't seem to get the machine off ventilate. I have followed the directions in the manuel. I have unplugged it, plugged it back in, pressed the menu/OK button which doesn't seem to work nothing happens. What am I doing wrong?
  • trishbrehl Sep 10, 2010
    I can't believe it!!! It worked . Thank you so much.
    Brigadier General:
  • 3,917 Answers
Hi
If ventilate stays on for a long time then the steam nozzle has become blocked - take off the nozzle and unscrew the top part then pull off the black component, rinse it, blow through it and if necessary use a pin or paper clip to to move out the debris.
Another easy fix is press the hot water button (with the raindrop icon) once. The message on screen will not change. Then, place a cup or other container below the steam wand and open the steam valve. The screen should read 'Hot water / Ventilate'. Leave the nozzle open until 'Ventilate' goes away.
However this procedure might take a while in some case.
Also you can try for factory setting.Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 09, 2010
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
Cant get the brewing unit removed from the machine? followed directions in the manuel but it wont budge
The lower catch tray and the dreg drawer must be removed first. Grab handle, push thumb on "press" button, give it a jiggle.
Aug 23, 2010 | Solis Master 5000 Espresso Machine
Kyocera FS-C5030N KX firmware update tool
you are overcomplicating it... all you need is a compact flash card big enough for the firmware... then you upload the firmware to the card and stick the card into the printer... but first power down printer and plug it out and then turn it on and follow the display... it will prompt you
here is the steps...
you will see ready
then press menu... arrow down to memory card
press forward arrow
you will see format
press enter
you will see processing
when its finished
you will see ready...
turn off machine... unplug it...
pull out compact flash
plug machine in
turn it on...
the **** for the compac flash is on the right hand side at the bottom by the ventillation opening...
Oct 09, 2009 | Kyocera FS-C5030N Led Printer
Printer says it's jammed with each and every copy.
It sounds like you printer does not know what size paper it has in the paper tray. Go into the menu and reset the paper size, If your printer is only 3 days old, Ihope the manuel is still around.
Good luck
Jan 13, 2009 | HP OfficeJet J4580 All-In-One Laser...
I have a hp officejet 6110xi all in one
hI,
the Issues seems to be with the hardware malfunction and it is not only related to the cartridge.
However, you can perform the following steps and in case if the issue persists, you need to replace your printer.
Connect your printer directly to the wall outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord
Regards,
sagarjd
Nov 18, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
My coffee machine says decalcify ventilate
For ventilate:
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Apr 27, 2008 | Saeco Royal Digital Plus Coffee...
Printer will not print
press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it .. then it ll prompt u for the language and country follow the steps it ll be resolved ...
Best of luck
Apr 01, 2008 | HP Officejet 4315 All-in-One Printer
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
Ventilate
bad chip get if repair my friend good luck.to verify keep it unplug for some days then replug back.but since the posing of this article,you can plug it now and lets see what happens.if it does what it do again call a tech.your machine has a bad chip if it is the embbeded chip buy a new machine.good luck my friend
Jun 15, 2007 | Gaggia Classic Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
41 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
