Question about Thetford Porta Potti
We have a new step style Thetford toilet in a brand new Rockwood trailer. When we apply gentle pressure to fill the main bowl water leaks over the small bowl at the back of the toilet and onto the floor. It appears the small bowl at the back may be missing a cover. As a temp fix I was considering covering with duct tape, but not sure how this would affect the function. Got any answers?
Sounds like the vacuum breaker is leaking. By small bowl at the top you mean the part that sticks up above the back of the toilet? If so, that is the vacuum breaker.
Posted on Feb 14, 2011
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Bowl turns on our thetford Aqua Magic Style ll rv toilet
the reason you are getting sewer gases are the wax seal under the toilet is not making proper contact with the bowl and flange....pull the toilet and replace the wax seal...buy a cant leak seal from lowes...may want to buy new bolts to reinstall...they sell plastic ones that you can cut easy after you tighten...make sure to shim the toilet if it moves...use toilet shims...also at lowes...this is why this happened to start with...it was not done right to start ...after all that caulk or grout bowl to floor...now you have a pro install...
Jun 18, 2014 | Thetford 42058 Aqua Magic Style II High...
I have a 4.8 lt flush vitra toilet when i flush hardly any water goes in the bowal to clean the sides of paper
These new style toilets are this way by design. It is designed to use less water, thus helping the. Ecology and your water bill. In effect what is happening is that the trap is lower in the bowl , thus not letting the level of water be as high in the bowl. Now matter if you pour a gallon of water to try to fill it up, it will run out until it reaches that level in the bowl.
Feb 25, 2013 | VitrA Aria Toilet with Elongated Bowl/...
I bought a 2003 rockwood popup camper. I hooked the water supply direct to the camper and the sink works shower works. I filled the resovor for the porta potti, and hooked the front battery up, but it does...
Hi cssweet12...
Look for a switch (inside cabinet,inside storage area, etc.) to turn the water pressure on from the pressure pump built into the camper..it will fill you toilet bowl with water one you have the system pressurized.
Trace your water line to locate your pump.
Please take time to rate me
Jul 07, 2011 | Home
Water is leaking slowing after filling up the tank and water supply is shut off. where is the leak?
In this toilet there is a flapper valve that blocks the hole for the water to transfer from the tank to thebowl. If you fill the tank and water is leaking into the bowl put your hand in the tank and apply alittle pressure to the flapper, the leak should stop. You can buy replacement parts for this toilet at Home depot or Lowes they carry universal lits that are perfect for this issue.
Jun 14, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
We have a water leak on a Thetford Style Plus toilet installed in our 2 1/2 year old Fifth Wheel RV. The toilet flange bolts appear to be tight and there is no visual evidence of black water leak or...
Thetford says that the vacuum breaker is usually at fault. I have the same problem. Try changing the vacuum breaker first (it is easier than the water valve).
Dec 23, 2009 | Thetford Porta Potti
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
Thetford Porta Potti  Logo
167 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
stynger007
Level 1 Expert
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
