I have an RCA Video Recorder Model # VR340, Serial # 041293114. I have not used the unit for 6 years but it has been in the stereo cabinet in a protected environment. I used the unit yesterday and it seems to work just fine and will play our old tapes - but they only come thru black and white. There is no color. What am I forgetting or missing to have the color movies that we have play in color? I want to use the unit to input a lot of old dance instruction tapes to a computer so they can be converted to DVDs. Thanks for any suggestions you can provide. Ed Marcato edmarcato@bigbend.net 432-371-2562
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
  • 360 Answers
SOURCE: The tape only plays back in black and white.
normally this would be a tracking error, if you can manually adjust the tracking, this should fix the prob...if there is no way to manually adj the tracking, use a video head cleaner to see if cleaning the heads will help the auto track to function better.
clarkco
Posted on Feb 09, 2009
SOURCE: Pass Thru, Analog Signal Converter How-To
Although I am not versed on your exact camera this suggestion ought to work.
Make sure the VCR connections are correctly made to the units OUT ports of video. I know this is very basic but double check each time you try a new arrangement. If the VCR has a S-VHS and the camera has s S-VHS use only that connection- VCR out to S-VHS on the camera. The camera will default to the correct direction.
Next make sure the camera is switched or dialed to VTR. This is a external physical lever or dial on ninety percent of camcorders. If someone has suggested using the Camera or record position this may be the problem.{ Even if the manual says to use a camera [software] menu selection while in the camera mode, that may be a second way if the first was not followed correctly.]
Again, all the camcorders I have used to pass thru, such as a Sony D-8 for conversion of Hi-8, have required the external selection to VTR as first step. The last suggestion is when this setup is done as described do not have a tape in the camera. That will cause the camera to default to the tape.
Once you have a signal shown on a preview screen that is what you see is what you get.
To summarize : Check connections from VCR out connecting to the camera's in ports. Attention to the color of the plugs also: yellow is usually video nowadays etc.
If you are fortunate to have S-VHS then only the single cord VCR to camera is used.
Make sure camcorder switch selection is to VTR and not Camera.
If you try this arrangement three times and it does not work I would strongly recommend downloading the free version of Nero. I think version .7 is now free if not then version .6 I like it because when you have the preview screen for Make DVD movie selected, there is a drop down menu on the top bar that will recognize what camera you are using. If the exact camera is not given try the others offered.
Once you have a working preview ,the bottom screen contros lighten and your camera is controlled by the VCR like controls for the preview screen. Nero is a simple, get it done program that has worked for me when my Premiere, Sony, Ulead etc. would not recognize the old Sony D8. Most of this is real basic, keep it simple, get done.
Good luck
Posted on Apr 29, 2009
You can hook up a converter box to your old VCR. You won't be able to program but you can record. If you want to program you can use one of the newer recorders that doesn't have a tuner and use the old vcr and converter as a tuner.
Posted on Oct 11, 2010
I need a free manual for my RCA VMT37F stereo console.
surely you jest . a manual for a 50 year old console stereo I burnt mine when the unit died 40 years ago .
Dec 21, 2015 | RCA Audio Players & Recorders
Connecting headphone system to a dvd recorder
does dvd record have head phoen jack out if not use rca outs in back rca to sterio mini jack to headphone wirless base ok
Jan 11, 2008 | Radio Communications
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Have a 1974 RCA stereo model:VCY350 I'm not
To what kinde of AMPLIFIER is the table connected to?? does the AMP have a PHONO input??? if not what input you are using on your amplifier??? or is this an all in one (cabinet) system??? can't google the model I guess it's to old even for a 43 year old tech. like me ha! (I was only 6 in 1974)
More information pleas!!!
May 26, 2011 | RCA Audio Players & Recorders
I have a sears console stereo recorder player model #528.30555400, serial #42471541. My problem is the needle fell off and I do not know how to put it back on? Can you help me?
Usually the needle is a part of the cartridge, and if it is not in a plastic holder intended to be removed, it is a permanent part of the phono cartridge and breaking it off requires replacing the cartridge as a unit.
Dec 27, 2010 | Soundcraft Spirit Epm 6 6 Mono + 2 Stereo...
Music and Sound Model N350. Two switches, one is labeled as AM, FM and Phono. The other one is labeled, Radio and Tape. Question, can a Phono or Tape be connected to this model or is the labeling just...
The answer is a year late, but yes, you can connect a phone or tape and even a recorder using the RCA plugs on the back of the unit. The tape input can be use to connect your stereo system so you have a whole house music system. The music will of course be in mono but the sound quality comes our better.
Dec 12, 2010 | Audio Players & Recorders
What year was my stereo model # VMT 34 S serial # 00660378 made
I was just given this stereo from a friend and it is missing the stylus and cartridge. (just bare wires to connect to) Do you know by chance what cartridge this unit uses?
Feb 17, 2010 | RCA Audio Players & Recorders
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
I have the Toshiba DVD/VHS recorder-player and was wondering do I HAVE to use RCA plugs to get it to work? or will any manufacturer's yellow/white/red video plugs work?
RCA plugs & yellow/white/red plugs are the same. They refer to cables used to transmit 'Composite' video (yellow) and stereo audio (red & white). RCA is the buzz word for the type of connectors they use. Probably invented by the company, RCA.
Feb 28, 2009 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
