Question about Sony DAV-DX255 System
Not getting any sound box just keeping saying protect, protect
  • Sony Master
  • 1,525 Answers
Hello it sound like the output transistor could be the trouble, or just may be a case of try joints or swelled capacitors all the best.
regards
shaun
Posted on Sep 09, 2010
Remove write protection on toshiba 2 gb sd card
Normally there's a small tab that needs to be slid to the opposite side.
Jan 18, 2014 | Electronics - Others
Please help my computer keep having a pop about a virus and worm but I already have Iolo protection but now it just locks everything up it keeps saying activate this new protection
Be real careful, because there are websites that will launch this dialog box and no matter which answer you choose.... YOU LOSE! because it'll install a virus..
Your best bet is a program such as NORTON Utilities or a reputable app.
Keep it running in the background and even if you run into one of these foney dialog boxes again, simply force quit your program without closing the dialog box... be careful..
Dec 01, 2009 | Computers & Internet
TV makes a ticking sound, red light comes on but no picture or sound?
The TV is on protect mode. The Ticking sound is the protection switc that keeps shutting down the TV to prevent more damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 30, 2009 | SharpVision XV-Z9000U Multimedia Projector
Wont turn on hear a faint click sound
The faint click sound is the protection circuit that keeps turning off the TV. This happens when an internal fault is detected. Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected. If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition. The flashing light indicates a diagnostic state called protection. When the TV goes on protection there are only two possible reasons. 1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit. 2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light. If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes. If you are in situation 2 , then there is an internal fault. Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board. Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable. If under warranty contact the manufacturer ringing the number on the user manual If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 05, 2009 | RCA P52812BL 52" Rear Projection...
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Power switch wont turn on,keeps clicking
The fault is not a relay, the clicking sound is just the protection circuit that prevents the TV from starting because a fault had been detected.
May 21, 2009 | Samsung Televison & Video
Tv would not turn on and it makes a clicking sound constinuously.
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 10, 2009 | Toshiba 27A32 27" TV
Bush 28inch widescreen tv
May 07, 2008 | Bush 2871NTX 28" TV
Clicking sound!
Apr 11, 2008 | RCA P60921 60" Rear Projection Television
Tv want turn on makes a clicking sound for about 3 sec like its trying to turn on but dont
Feb 11, 2008 | GE 31GT740 31" TV
Sony DAV-DX255 System Logo
56 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
