Question about Ruud UPMC036 Air Conditioner
Unit does not heat or cool. Starts to operate if I spin the fan. Failure appears to be caused by the starting capacitor. However, there are two capacitors one with two leads and one with several. The two lead capacitor is connected to a relay. Which capacitor is suspect bad?
    President:
  • 1,515 Answers
Look at the top of the capacitor that has several leads to see if it is a dual cap. It will have 3 sets of connectors in a row and if you look close, they will be numbered with these markings, C for common, Fan, for the outdoor fan motor, and Herm, for the compressor. This would be the one. Look it over to see if the top on either one is raised up, swollen looking, leaking oil or deformed in any way. If so, the cap is faulty. It may just be your motor going out. This motor gets a lot of run time in the summer, and if its a heat pump, the winter also. If it tries to take off when you spin it, sounds like the windings are weak. But, it would be much cheaper if it was the capacitor. If you are going to have it tested for the proper microfareds/uf's, make your self a drawing of all of the wires and where they go, so you don't forget. This happens a lot. The capacitor will have markings like this on the side. 55ufx370 volts or 440 volts and the fan will be 5uf's x 370 volts or the numbers may be higher or lower depending on the tonnage of your unit, just to give you an idea. Please keep me posted and get back to me and let me know what you are able to find out. I will be here if you need my help. Don't forget to rate me as I know you will be kind. Keep me posted for sure. Thank you,
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Sep 09, 2010
Testimonial: "Great sugestions and write-up!"
  • ottobahn Sep 09, 2010
    When I entered the unit info I attempted to change the model to UPMC-042 but apparently it didn't take. I just found the schematic for the air conditioner and it shows the start capacitor, run capacitor, and start relay. When I spin the fan (just barely moving it,) the heat pump starts and operates as required until the desired temperature is reached. I inspected the start capacitor and it visually looks ok. It's a 88 - 106 mfd 330 volt cap. I'm going to replace it to see if it corrects the problem. Because the unit operates as it should when I spin the fan I'm thinking the cause is either a bad start cap or relay. Your information was very helpful. I hadn't considered the operational time of a fan during the winter and summer. I have no way of checking the cap so I'll try replacing the least expensive part first. Thanks for your help!
  • Robert Horton
    Robert Horton Sep 09, 2010
    Thank you for the awesome rating, and I am happy I could give you a place to start. Its best to take the capacitor in to a appliance retail parts house and they will test it for you. It does sound like it may be the run cap for the fan now that I know you don't have a dual capacitor and the fan will run after you spin it to get it going. I am pretty sure you will get away with a new cap. They are around $14 to $20 dollars, so I wish you the best.
    Shastalaker7
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
Apr 12, 2017 | Heating & Cooling
We have one of the ACC108PS air conditioners that is not cooling right - do we need freeon - if so is it rechargeable?
Start your window air conditioner troubleshooting with checking the different modes of operation to see which components operate. Turn the unit fan to on and the cool and heat modes off. If the fan does not operate, check the power supply to the unit. Check to see if the breaker or fuse for the unit is tripped. If the breaker/fuse is tripped, check to make sure that it is the proper size circuit for the unit you have. On some units, there is a current interrupter on the power cord to the unit. Check to see if it is tripped by pushing the reset button.
If the circuit is the proper size, then you can go ahead and reset the breaker/fuse. If it trips again, then you require further troubleshooting. Shut the power off and check all of the wiring in the unit to make sure that none of the connections is loose or damaged.
If the fan does not operate but the fuse/breaker is not tripped, you should check the run capacitor for the fan and compressor. If the capacitor is good but the fan motor does not operate, you can check the fan switch and the fan motor. Ensure that the fan blades spin freely.
If the fan motor operates but the compressor does not start, change the capacitor but first you should feel the compressor with your hand. If it is very hot, then you should allow it to cool.
Then, you should attempt to start the unit in the cooling mode. As you do so, listen for a clicking sound which is an indication that it is attempting to start. If the compressor starts but does not cool properly, the unit may be low on refrigerant.
If the compressor attempts to start but shuts off very quickly, the compressor could be bad. You could try installing a "Hard Start"
If the compressor does not attempt to start, ensure that the thermostat is set below room temperature. On units with a mechanical control, you will hear a click when you adjust the temperature. That is an indication that the thermostat is working properly.
Jul 12, 2011 | Whirlpool ACC108PS Air Conditioner
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
The fan on our heat pump is not spinning. If we a...
Is the compressor running? Take a look at the contactor in the outside unit and see how it looks and if it is pulled in energizing the fan and compressor. If the compressor is running then check for voltage at the fan. If you have power at the fan and it isn't running then turn the power off and check the capacitor. It may have just 1 for both the fan and compressor. If the capacitor is ok then the fan motor could be bad. You will need a multimeter with a capacitor check function to test the capacitor. Hope this helps. Let me know what you find.
May 21, 2010 | Heating & Cooling
The pc is switching on and then off after 5 minutes
There are several factors that could cause the above problem in your diagnoses.
A) Processor Fan is not operating, or not spinning at the set speed desired. (RPM. Revolutions Per Minute) Fan bearings are bad.
Replace processor fan.
Computer case open, observe the Processor fan as soon as you start the computer.
If the fan is not spinning, shut the computer down.
(Hold the Power On button in for a count of 10 seconds)
Observe if the fan spins slowly, or spins for a while, stops, then spins again.
B) Failing Electrolytic Capacitors on the motherboard.
C) Power Supply has a weak voltage power rail.
Failing Capacitors on the Motherboard.
Electrolytic Capacitors.
Specifically the one's used in the motherboard Voltage Regulator Circuit.
A Processor must have a Steady, Clean, supply of voltage.
The tolerance range is Very small.
Too little, or too much voltage, the Processor turns off.
[BIOS turns it off]
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor.
This link gives information about what Electrolytic Capacitors look like installed on a motherboard, and photos plus info, about the visual signs of Electrolytic Capacitor failure,
http://www.capacitorlab.com/visible-failures/index.htm
(Computer unplugged from power. Observe Anti-Static Guidelines. Need more info about the last sentence, please post in a Comment)
Requires either replacing the failing capacitors, or replace the motherboard if bad capacitors are found.
If upon a close scrutiny with a flashlight, and magnifying glass, does not reveal visual signs of capacitor failure, then the next hardware component to check is the Power Supply.
3) Power Supply's have Electrolytic Capacitors also.
A computer power supply changes AC (Alternating Current) electricity from a household, or business, into DC electricity.
(Direct Current. A flashlight battery is an example of stored DC electricity)
Electrolytic Capacitors are used as Filters in a computer power supply.
They filter the incoming AC (Input Stage), and the outgoing DC (Output Stage)
Generally I have found that these are the weakest link, and are the first hardware component to fail in a PSU. (Power Supply Unit)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
There is a way to test the Power Supply.
Requires either a multimeter, or a Power Supply Tester, or using a KNOWN to be good, compatible power supply to substitute, and use as a test unit.
An economical multimeter can be purchased for around $10 to $15 at many stores. An auto parts store usually carries them.
An economical power supply tester can be purchased for around $20.
This is an example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Computer dirty inside, as well as the inside of the Power Supply, will cause detrimental factors to the computer.
1) Dust is a Static magnet. Dust can create pathways for static electricity to follow, and the DC electricity used for a computer.
This can cause hardware components inside the computer to Short Circuit. (Fry out)
2) Dust, dirt, hair, etc, can clog the cooling components of the computer.
The computer case fan/s, the Processor fan, and Heatsink, and the Power Supply fan, and Heatsink/s located inside the Power Supply.
Air is drawn in through the front of a computer, (Or on some custom PC's through the side), and flows over the hardware components inside the computer, helping to cool them.
If a layer of dust, dirt, hair, and so on, has coated these hardware components, the heat will be trapped, and the air flow will not be able to carry the heat away.
If the computer case fan's are coated, their cooling capacity drops tremendously also. The fan, or fans, will not be able to provide the air flow needed.
If the Processor fan, and Heatsink are coated, the cooling capacity of these two components drops tremendously.
A Processor has a thermal temperature it can operate in, and will turn off if the temperature is exceeded.
It's a Fail Safe feature that is built-in, to keep the Processor from burning up.
[A Heatsink is essentially a plate of metal that has tall, thin fins protruding from it. Heat is absorbed into the plate, whereby it is then absorbed by the tall, thin fins.
Air flows in-between the fins, and helps carry the heat away.
This is an example of an average Fan/Heatsink combo,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2604150&CatId=493
The Heatsink is the aluminum finned part sitting under the fan.
Using a can of compressed air for computers, on a regular basis as needed, can help prevent many computer failures.
To summarize:
1) Check the Processor fan. If the computer is dirty inside, there is the obvious factor for it's failing.
2) Check the capacitors on the motherboard visually.
3) Test the power supply, or substitute it with a Known to be good, compatible unit for a test.
[Compatible
Must have at least the same amount of Wattage, or more.
Must have all the correct power cables needed.
Must have enough of the correct cables]
May 17, 2010 | Computers & Internet
ACE184XD1 will not heat or cool. Fan works fine.
If your fan is working this is a good thing. So we know we have good power to the unit.
Your going to need to remove the cover from the unit, remove several screws to get access.
Make sure power is off and where the compressor is, on top remove the cover where the power connects inside and make sure there is no wires burnt, if all is well, move onto the capacitor.
Its usually the cause of compressor failure. Write down where the wires are located on the capacitor (read the top of capasitor) and take the capacitor to a local appliance supplier and have them test it and if bad then purchase a new one and replace in your unit.
Also make sure to verify no wires are burnt in the unit or melted together, and it never hurts to clean it while you have it out.
Good Luck!
Nov 14, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
External fan stops operating in hot temperatures
Replace the motor on the outside fan, It should run all the time.
Jan 07, 2009 | Heating & Cooling
Ruud UPMC036 Air Conditioner Logo
149 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
