Question about PfaFF Sewing Machines
Hello, i just bought my new pfaff expression 2.0. the machine does not loop properly. the bottom thread seems to be very loos. if i adjust the bottom is too firm. could you advise please. therefore my zig-zag stitch is puckering the fabric. i am an experienced taylor but run out of ideas how to resolve this. i am very upset thank you for your help
  • 161 Answers
Honestly, if its a new machine i'd be taking it back, as you may have a lemon. I don't think you should have to adjust anything on a new machine, and if there is some trick to threading it so it works properly you'd be better off hearing about it from the people who sold it to you. perhaps one of the guides has some packing in it as its new??
Posted on Sep 12, 2010
My Pfaff Expression 2034 sewing machine is suddenly making an almighty mangled mess at the bottom - it doesn't matter how I re-set the tensions. What can be the problem?
Be sure to use a brand new needle.
Remove the upper thread and bobbin. Reinstall the bobbin making sure it is turning the correct direction and threaded properly in the bobbin case.
RAISE the presser foot and rethread the top thread. Confirm the thread pathway is correct.
Most often, knots (thread nests) occur under the fabric because the machine is misthreaded or the thread is not seated completely in the tension disk.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Sep 22, 2016 | PfaFF Sewing Machines
I have a pfaff 4.2 quilt expression brand new but cant make it work. The thread in the bobin keeps jamming? What cani do
thread jams or breakage generally points to incorrect thread tensions
read the hand book and adjust accordingly
Jun 10, 2015 | PfaFF Sewing Machines
How to adjust the tension disks on my Pfaff sewing machine?
Make sure your bobbin is the right size. If it is too high it won't turn freely. Also, make sure you drop the bobbin in so it rotates clockwise. The tension must adjusted by hanging the bobbin from your hand and bob it up and down gently. It should move about one inch downward once adjusted properly. The hole in your plate should be checked to ensure the center where the thread dispenses is smooth. Use a finger nail file to smoothen if needed. Now, adjust the top tension to four. You may need to adjust just slightly. Just remember when you remove the bobbin assembly to put a drop of oil on the race. (Many forget this). When you rotate the handwheel towards you the bottom thread should come up. If this doesn't happen then you will need to have adjustments made.
Jul 31, 2014 | PfaFF Sewing Machines
Pfaff machine -sews with thread loops forming on the underside of the fabric.
This is usualy a thread tension problem. Adjust the upper thread tension first. If tightening the upper thread tension doesn't work, then adjust the bobbin holder (lower thread tension) check with the user manual for your specific machine for the correct procedure.
May 17, 2011 | PfaFF Sewing Machines
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
Pfaff 1475 tension problem.
Many users also reported similar bobbin tension adjust problems. But do you know it can be fixed by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Jun 21, 2009 | PfaFF Tiptronic 2030
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Pfaff Expression 3.0 works great in the shop, but when I get it home the bobbin thread doesn't engage with the needle thread. The needle thread ends up making large irregular loops on the bottom of the...
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
Apr 12, 2009 | White Sewing 1521
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
91 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
