Question about Whitehaus Plumbing
Kitchen faucet-Whitehaus brushed nickel # WHKBLV 9101BN. The spout leaks at the base, and our plumber's washers won't fit. We paid a bundle for this! and I hate to replace it with a cheap faucet. Do we need a washer or what? If so, who can send and how fast? Thanks, John Kuhnle 202/255-9476
  • 20 Answers
John, there should be a parts diagram online. You will need to order the correct orings and install them using plumbers grease for lubrication.
Posted on Sep 16, 2010
How do I fix leaking tap?
Get a plumber 2 do this operation 4 U!!!!
Jun 29, 2014 | Hansgrohe 16502821 Axor Montreux 2-Handle...
Tip
How to rebuild a single handle delta kitchen faucet.
Step 1- Shut off water supply to your faucet.
Step 2- Use 1/8" allen wrench to remove handle from faucet.
Step 3- Next it has a retaining ring to loosen, they make a little spanner wrench to fit this in all complete rebuid kits. And then you are ready to loosen the collar.
To do this would be best to have a tool to grip the collar and not do damage to it. Some hardware stores carry rubber slip on's to fit on chanel locks pliers to avoid marking. Or if you have access to a strap wrench that will work.
Step 4- After collar removed, remove plastic cap and washer and ball. Seats and springs are located in valve bottom. Remove seats and springs with a small screw driver.
Step 5- Pull up spout to remove it to replace the o ring's on shaft. Also if it has a sprayer the diverter is in the base near the bottom. A little round brass diverter for sprayer.
Step 6-Install o rings for spout on base and diverter for sprayer if it has one. Plumbers grease will make install of spout easier to go back onto base. Now you can reinstall spout back onto base .
Step 7- Install new seat's and spring's with a small screw driver. Line screw driver to port and let spring and washer slide into place and press it gradually into place to seat in.
Step 8- Install new ball and notice that it has a groove in it to line up in valve.
Step 9- Install washer and plastic cap with slot in proper space.
Step 10- Install cap and tighten and adjust retaining ring to tighten up movement from spout from side to side. At this point you can turn water back on to make sure you have no leaks before tighting handle in place.
Step 11- Install handle and you're in business, and have rebuilt your very first faucet with knowledge to tackle the next plumbing project. Take your time and look closely how everything is put together, so you will know how it goes back together.
on May 28, 2010 | Plumbing
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
How do I replace a spout O-ring on an American Standard Jasmine Hi-Flow Kitchen Faucet, 3821.831 or .834. I'm trying to get the spout assembly off to get access to replace. Thanks in advance!
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
Jun 03, 2011 | American Standard Jasmine 3821.831.295...
American Standard Jasmine 3821.834 leaking where spout enters base
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Mar 29, 2011 | American Standard Jasmine 3821.834.295...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Plumbing Logo
238 people viewed this question
Top Whitehaus Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Whitehaus Plumbing Expert? Answer questions, earn points and help others
