Question about JVC HX-C6 Shelf System
My JVC stereo receiver CA-HXC6, how do i get itout of protect mode? it turns on then goes right to protected and turns off
Google stk428-610 ic an stk428-640 ic an replace them , they have to be solder in , don't try this if u don't have experience
Posted on Oct 19, 2010
My jvc stereo is stuck on protected and it won't change the radio station off protected
Radios that are in "protected" mode often indicate a short in a speaker wire or a really bad speaker. Disconnect all eight speaker wires: white, white/black, gray, gray/black, green, green-black, violet, and violet/black. Turn on the radio and see if it still shows "protected". If it does, the radio is defective. If not, connect each pair of speakers back one at a time and see if it goes into protected mode. The one that causes it is the bad wire/speaker.
Dec 22, 2013 | Car Audio & Video
My jvc deck says PROTECT on it and won't let me listen to music or anything! What should I do?
my jvc kd-s37 keep going into protect mode now how can i get it where it stays out i reset it several time but it still goes back into it
Nov 25, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
I have a jvc ca-mxkb25 house stereo which when its turnt on it says on the display overload
i have the jvc ca-mkkb25 3 disk music system how do i get the disk door open when it says locked
Sep 12, 2008 | JVC Audio Players & Recorders
Protecked mode?!
when i had this problem my wires were touching the case. other times the wires were touching eachother
Mar 23, 2008 | JVC MX-KB30 CD Shelf System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Protect
hi, ya absolutly... please check the speaker wires, some wire is shorted, remove all the speaker wires from the system and then power it on to confirm it.let me know
Jan 03, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Protect
Protect mode would indicate that the system is shutting down due to a fault in the output which drives the speakers. You can check the speaker wiring, are there an loose or frayed wires? Any small "whiskers" or wire touching anything? Check the wire all the way to the speaker for damage, some pets love to chew wires! Are you using the original speakers or added extra? The impedance of the speakers must be in the range shown on the back of the unit. Have you perhaps had the volume up very high? This could result in speaker damage that could also cause this error. Try disconnecting the speakers & see if the unit powers up, if it does then put the speakers back one at a time to discover the faulty one. If all this checks out OK then the output stage itself is probably faulty & that's a job for the repair shop. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | JVC HXC6 500-Watt Stereo System with 5-CD...
JVC HX-C6 Shelf System Logo
819 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
