Question about EnGenius ESR-1221 EXT Router
How do I configure an EnGenius router? Specifically, I need to enable the port forwarding feature that was disabled by the router vendor.
  • 53 Answers
SOURCE: 3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Posted on Feb 04, 2009
tunmun
  • 413 Answers
SOURCE: Linksys EZXS88W pass-through port problem
Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
Type your username & password and login to device.
A web page will appear , you can go to security section & select virtual servers.
From virtual servers section you can create port you want either TCP or UDP.
Thanks and Regards
Posted on May 12, 2009
dante777
  • 623 Answers
SOURCE: I would like to configure port fowarding on the CISCO 857 Router
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 24, 2009
Macs R We
  • 481 Answers
SOURCE: cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
Posted on Oct 28, 2009
Macs R We
  • 481 Answers
SOURCE: i am configuring a engenius
Every node added to a WDS network cuts the network transmission speed in half. This is just a characteristic of any WDS connection, as WDS is a repeater protocol (it has to retransmit everything it receives).
It's not clear from your description whether you are trying to add the EOC and the Cisco to the same WDS network. If that is the case, it's a wonder you got it to work at all, since WDS implementations are model-specific, and usually require every node to be exactly the same model router.
Posted on Oct 27, 2010
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I have a belkin n modem router and it keeps kicking the xbox off line. is it the xbox live or my new router
it is the problem with router....the firewall built-in in the router will not allow certain gaming devices to go online...for this purpose you need to forward certain ports in the belkin router...for the list of port numbers to be forwarded, contact xbox vendor....once you got those port numbers, you can call 24x7 toll free belkin tech support(1800-2-235546)(1800-2-belkin) and ask them to assist u to forward ports... or you can can connect a computer to one of the wired ports(1 to 4) and open internet explorer and type 192.168.2.1 in address bar and hit "enter key". you ll see belkin router setup page...on the left side you ll find "virtual servers"...open that link(if it asks password, leave it blank and click submit) fill the IP address of your xbox in that form and type the port numbers and select appropriate (tcp/udp)... also click on"firewall" in left and disable it.... also click on DMZ in left and type your xbox ip address there and enable it... thats it.... you are done with that...
Apr 13, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My wireless adapter light is green, yet i cant connect to xbox live!
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 08, 2010 | Microsoft Wireless Network Adapter Xbox...
My email does not come thru when my computer is connected to the router
did it work before? what did you change on your router? can you change it back?. does it work when you computer is directly connected to your modem?
if you download your email into an email client (outlook, outlook express, other)? you may need to configure the port forwarding on your router to allow the port used for this type of information to come through.
first find out the ports used, (if you use pop3 the port number is 110) but find out what specific ports are being used as per your email client configuration.
now go into your router's configuration page and go to the port forwarding section (under advance configuration) on you router and enable these ports if they are not enabled already enabled. (if your router is in fact blocking this ports this where the blocking happens) unless there's a good reason for you to configure this, do it otherwise leave the advance settings alone.
your router manual can be found here
good luck
Dec 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
cisco(config)#
in you case:
and
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Problem with firewall rules and access from WAN
  • call your router support to disable first the firewall on the WAN setup
  • the do port forwarding
Aug 10, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
Webcam Access through SB4220 Cable Modem?
it sounds like you have configured the router correctly. what you might be doing wrong is trying to access the camera from your internal network using your external ip address. this will not work... you need to get someone on the "outside" to try the ip address.
Jun 05, 2009 | Arris SURFboard SB4220 Modem
EnGenius ESR-1221 EXT Router Logo
107 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
