Question about Welbilt MR755T Microwave Oven
Looking for Galanz Microwve Ceramic fuse, F15H, 250V, 15 amps, approx size is 3/4"
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
I need a new fuse for my Galanz Microwave. its a 15amp ceramic 250V fuse. small size
jut click here and you'll be redirected to retailrs website's exact page
http://www.thefusecompany.com/index.php?cPath=36
Jun 11, 2009 | Microwave Ovens
Fuse is blown
It's 20mm !!
It will have failed for a reason.
At 15amps, I'm guessing your Microwave has a grill too.
It could just be a bulb failure causing the fuse to blow.
Replace it and try again.
If the oven works but no light, that was the cause.
Apr 26, 2009 | Microwave Ovens
I got a Galanz microwave Moldel # P60D17L-D5 and cannot find a ceramic fuse anywhere it's 3/4 inch long and 1/8 inch diameter. I've tried emailing the company but no reply's.Anybody got any idea's
The microwave oven use a slow-blow fuse. If you look on the around the end of the fuse, you will be able to tell what size it is. Example (250v 3Amp) Your fuse may be found at Hardware stores in the electrical isle or a Radio Shack. If you found my suggestions to be helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Where to purchase a new fuse for Galanz Microwave
20A ceramic fuses can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Feb 13, 2009 | Welbilt MR755T Microwave Oven
Service
It should be marked on noted on a tag near the fuse holder, but commonly it;s 15 or 20 amps, and it should be ceramic (white or gray).
Aug 16, 2008 | Microwave Ovens
Microwave Ovens Logo
228 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
