Bulb has blown on Zenith LCD Tv, got the bulb out that is incased in black metal housing. Looking for replacement. #'s on the back of the case are 4810v00710 PPS+BF40X
5 Suggested Answers
SOURCE: ZENITH E44W46 LCD HDTV
Its your light engine failing. It can cause different colored "spots or ovals" to appear in the black background.
My Zenith ( now LG ) E44W46 LCD had the engine replaced after only 10 months, and now 3 years later it is failing again. There is a lawsuit against LG for using defective engine assemblies in this particular model.
After much searching I located this number, 800.243.0000 and called from work this past Monday at 8:15 a.m. central time. I was blown away to actually have someone pick up and direct me to a rep who reassured me that LG was aware and has set up a department to handle claims.
I was issued a case number and told that I will be contacted by a rep from this "department" and they would replace the set. With what I don't know yet but I will post back after I get thier final answer and the details.
Posted on Dec 31, 2008
SOURCE: lcd projection tv kdfe60a20 6 red lights flashing
where is the thermal fuse kdf-e-60-a20 sony
Posted on Dec 02, 2009
  • 117 Answers
SOURCE: Black screen. Does the bulb need to be replaced?
no bulb in lcd silly/does it flash when powered on its
the ctrl/lvds controls back lighting buddy
Posted on May 01, 2010
  • 129 Answers
SOURCE: My COBY 33" LCD TV will not show the picture
Try connecting the TV directly to a different wall outlet. Then, try power resetting the TV.
Turn Off the Tv and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the issue still persists, then the TV requires service.
Posted on Jul 26, 2010
Should I replace the bare lamp or the complete housing for the bulb in my Zenith E44W46LCD TV?
Replace it with the complete housing with a bulb inside.The easiest and the safest way to do a replacement of a tv projection lamp.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Need to replace headlight bulb. how do u do so
if you are wanting to take out the light housing... -- remove the black plastic cover (flat head screw driver and needle nose pliers work well for me) use the screw driver to lift up the head of the black plastic "bolts" (i'll call them) and then either pull them out by hand or with the needle nose pliers.
  • ** note: make sure you take the entire plastic bolt out, there are two parts**
Remove black plastic cover -- remove the two bolts/screws (2 for each headlight) -- carefully pull the headlight housing out
** NOTE** the bulbs will still be attached so be careful
Then twist the bulblight socket (to the left) and pull it out.
Repeat the steps in reverse order if replacing just the housing
If you want to replace the bulbs follow the below procedure
  1. Once the socket is out of the housing, gently pull the bulb out. (may want to use a rag/glove/towel incase bulb breaks)
  2. Take new bulb and (using rag/glove/towel) push the bulb back into the socket and then repeat the above steps in reverse...
Nov 10, 2009 | 1997 Pontiac Sunfire
Replacing bulb
on the lower right hand side just below the model and serial number is the access panel for the bulb housing. remove the screws to the panel and housing. *remember* when replacing the bulb !!!DO NOT!!! touch the new bulb with your bare fingers. get some rubber or latex gloves
Sep 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
How can i replace the lamp by myself
if you are standing in front of the TV, look on the right side. There is a door with two screws (phillips) remove the two screws and open the door. Inside you will see a black object with a silver handle and two black screws. remove the screws and pull the lamp straight out by the handle. I you buy a factory bulb, you can just slide it right in. If its an aftermarket bulb, then you have to put it into the housing. Be careful not to touch the glass portion of the bulb with your bare hands. the oils in your skin will shorten the life of the buld. Just like replacing a vehicles bulb. hope this works for you.
Jun 24, 2009 | Zenith E44W46LCD 44" Rear Projection...
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
Wont turn on and front lights blink
Start by checking the lamp, there's no sure fire way to tell if its the lamp or not.Remove the lamp housing door off the back right side of the tv (if you are looking at the back of the tv, it has one black screw holding it in place. Look inside and you'll see the black and silver metal housing. Then loosen the gold screws on each side of the lamp housing. You'll know you're looking at the right thing because there is a black handle that lets you pull the housing straight out (after loosening the screws, the screws wont come completely out). Take into account the amount of time it has been since you replaced the lamp, 3-4 years seems to be about average. You won't really be able to tell if the lamp is burned out or not by looking at it. Sometimes there is a break in the glass tube inside the bowl, sometimes its a white powder in the small bulb at the bottom of the glass tube. Either way, use the stickers on the housing to get your lamp number and order a bulb. Rivervalleyelectronics.net is a great place to look. I use them all the time. Any osram or philips bulb off ebay will work fine too. Email me directly if you need further assistance. Cfoley@hawaii.rr.com Good Luck
Apr 06, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD bulb replacement
yes , panel is on the right side if your looking at the tv,
Dec 31, 2008 | Zenith E44W46LCD 44" Rear Projection...
Kdf-e55a20
In my experience with these models, if have found that your fault could be due to a blown bulb assembly. This can easily be checked by looking up the bulb replacement procedure in the user manual. The bulb should look clear and see-through to the tip of the filament. There must be a small class pipe inside which has a wire connected to the tip.
Any white residue or black discoloration inside the bulb indicates a blown bulb. You can contact your nearest Sony service centre for a new replacement bulb. Write down the "XL-xxxx " number as you will have much faster result than giving the model number.
If you need any more assistance please post a reply.
Best of luck.
Mar 02, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
