Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Hello, The Hub Assembly in my Delta Signature Pull-Out Kitchen Faucet, gets jammed turned to the right, and will not rotate any more. In past, I have temporarily restored rotation by applying WD40 and or Shredder Lubricant oil to the top and bottom surface joints of the hub. It now seems permanently stuck. Please let me know how to repair this part of the faucet.
  • annebatten Sep 10, 2010
    Amazing! Many thanks for the terrific advice. Delta's customer services are the best--one short chat, and the replacement part is on it's way to me (free of charge). This is an up-dated part, one the company has redesigned so as eliminate the sticking problem. They've even offered to talk me through installation, should I need help.
    This solution was very helpful, indeed an ideal solution to the problem.
  • 905 Answers
Hello Anne,
Given that *most* delta faucet products are covered by a lifetime warranty, you need to start by contacting Delta directly.
1?800?345?DELTA (3358)
Delta Faucet Company Product Service 55 E. 111th Street Indianapolis, IN 46280
You might also be able to obtain warranty assistance by contacting the retailer / dealer where your faucet was obtained from.
Posted on Sep 10, 2010
  • Sheldon Dedek Sep 10, 2010
    You are welcome. Glad that your faucet wasn't one of the few that aren't covered under the lifetime warranty. I have dealt with Delta customer service in the past, they truly are top notch.
    Please don't forget to rate / accept my answer to your question. Have a great day!
How do I remove the hub on the faucet to get to the o rings
There is a set screw under a removable button cover on the handle. Remove screw to disassemble and access cartridge. See link. http://www.deltafaucet.com/media/MandI/76075%20Rev%20B.pdf
Feb 22, 2015 | Delta Model 470: Signature Kitchen...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
Sticking of KWC DOMO model faucet.
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
May 11, 2010 | Delta Model 470: Signature Kitchen...
Hi While I try to rotate the tap , the whole base is rotating with it ( delta 470 ss)
A "basin" wrench will be needed to get up under the sink/faucet base to tighten the nuts that hold the faucet in place. It's a simple job but requires the agility of a contortionist to get at.
Apr 26, 2010 | Delta Model 470: Signature Kitchen...
I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
Mar 19, 2010 | Delta Model 470: Signature Kitchen...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
764 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
