Question about IBM Wheelwriter 30 Typewriter
I have a wheelwriter 3000. I'm typing info in blocks. My typewriter is set for line space 1. I want to type exactly in the middle of the preprinted box, if I use the line up or down key, this will not get me lined up exactly, to much spacing. Is there a way you can use the line up and down key that will do a 1/2 space, so when I use the up or down key I will have the same setting all the time. I don't have a carriage handle that I can move around. I do have 1/2 space key, but it will only let you do one letter at a time not a word, when you type one letter the carriage will jump back down.
  • IBM Master
  • 3,594 Answers
Hold the code this makes the index a micro index for fine spacing.
DickyO
Posted on Sep 09, 2010
  • beverly_sipe Sep 09, 2010
    Thank you. I also found out if you hit the paper up or down key without the code this will do 1/2 line spaces. :)
Why won't it release margins?
The margin release mechanism has become defective.
Jan 08, 2016 | IBM Typewriter - Wheelwriter 3000 by...
We have ibm wheelwriter 3000. When typing it makes a beeping noise. Tried to release margins, but still beeps
If it beeps on every key stroke try code "S" If it beeps once in a while it may be the spell check code "1" will turn that off. If it always beebs at the same place the R. margin is probably set there. Space all the way to the R. and press R. mar key.
DickyO
Aug 16, 2011 | Lexmark Wheelwriter 3000 Typewriter
How do I support and reprint a repeated signature block?
On the L. side of the KB there are 3 keys save, play & delete. Hold down the save key press address 01-99 release save key type info. press save again.
To replay hold play key and enter the address, rel play info will type.
Delete works the sameas play
BE SURE THE BATTERIES ARE GOOD OR INFO WILL BE LOST ON POWER OFF!!!
DickyO
Nov 02, 2010 | Lexmark Wheelwriter 3000 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
I HAVE BEEPING ON MY WHEELWRITER 1000 ON LINE SPACING 1 & 2
The keyboard is probably bad and the typewriter can't see it.
Contact George Beters CO. 1-800-392-8085.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 3000 -- need to program
There are three keys on the L. side of the keyboard store, play & delete that control the memory. Hold the store key and press 00-99 to set an address, rel. store type info. then press store again.
To play back press play and the address.
DickyO
Dec 12, 2008 | Lexmark Wheelwriter 3000 Typewriter
Continous blinking between the line spaces 1 and 2
It sounds like a bad keyboard to me, it can be rebuilt. Contact George Beyers Co. for a quote, usually about 50.00
Hope this helps
DickyO
Feb 21, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
Ww302 indexing
There is no line space setting other than 1, 1.5 & 2, if tou are typing on a preprinted form it may be out of registration (6 lines to the inch).
Dec 20, 2007 | Lexmark Wheelwriter 1000 Typewriter
Will not type
If the 1, 2, and 3 line space keys are flashing in order, you need to change the two AA batteries that are located inside your typewriter.
May 23, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
