Question about Stairmaster 4600 Cl Cordless Freeclimber
Both pedals slipping to floor as if no power was getting to it. screen reads stepper when first plugged in
  • Stairmaster Master
  • 914 Answers
I would start with checking your brushes in your alternator. If they are worn down, they will not make good contact. The resistance in this machine is provided by the alternator.
Testing Alternator of Stairmaster Steppers 4400CL 4600CL SC916
Posted on May 21, 2014
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Left pedal on stepper falls to ground in workout
YOU MAYBE HAVING AN ISSUE WITH THE SPROCKETS THAT HOLD THE DRIVE CHAINS ON BOTH PEDALS. YOU CAN PURCHASE THEM SEPARATELY OR A COMPLETE HUB ASSEMBLY. TO REACH STAIRMASTER/NAUTILUS @ 1-800-864-1270
Posted on Mar 01, 2010
I have a 440pt and the left pedal is skipping down to the floor about every 5 seconds. If the issue is the hub assemble, do I have to change out everything or can I just replace the bearing, etc...?
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Sep 05, 2013 | Stairmaster 4400PT FreeClimber
Stairmaster 4000pt pedal slips
Jul 07, 2012 | Stairmaster 4600PT Stepper
I have a Stairmaster 4000PT. When using it, the left pedal will suddenly drop to the floor. Opened the case. The spring is intact. I used it with the case open and didn't notice anything different...
Sep 02, 2011 | Stairmaster Exercise & Fitness
Should stairmaster pedals go to floor if you don't keep pedaling? once I keep pedaling they go back up, but if I just step slow they drop to the floor and do this when you first get on as well
This is exactly the way the machine was designed to work. The attached link will take you to our Website. There you can find more information about your unit. Including the Owners/Operators manual, the Service manual, diagram and parts for the unit.
Stairmaster Stepper 4600PT Parts Hub Assembly Spring SPORTSMITH net
Aug 04, 2011 | Stairmaster 4600PT Stepper
The left peddle has a periodic quick drop as if it is slipping or something. There is a low popping sound whenever this happens. The drop is very slight and occurs about once a minute.
Mar 17, 2011 | Stairmaster 4400 PT Stair Stepper
My battery needs replaced. Where does the new battery go? Can I get an A/C power source instead? I go to LifeTime Fitness and all of their Satirmasters are plugged into an outlet on the floors. Seems like...
yes you can get an adapter to plug it in . go online to sportsmith fitness products they can also provide you with a new battery as well
the battery is located on the right side of the machine when your are standing in it, push both pedals down with your knees and remove the small cover in front of you carefully .release the pedals , then remove the right side cover (remove the push pins on front and bottom of cover ) it will be a little tricky without removing all the covers but be gentle, do not force it too much. you will see the battery to the upper left. as you will see it is easy to remove and replace
Jan 29, 2011 | Stairmaster 4400CL Stepper
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
Where in the world is the battery for the Stairmaster 4200 PT? I have read the manual multiple times and taken the cover off and still can not find it. Help!
There is not a battery in this unit. Stairmaster steppers that require a battery are labeled as CL for cordless. The PT machines have a power supply that plugs into the wall.
Stairmaster Stepper 4200PT Parts Eccentric Hub Pedal Arm SPORTSMITH net
Sep 12, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Feb 26, 2010 | Stairmaster 4600PT Stepper
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
Stairmaster 4600 Cl Cordless Freeclimber Logo
143 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
