Question about Emerson MW8777W Microwave Oven
When I try to use the microwave, it counts down the minutes and seconds I set it for, but does not heat food. The turntable doesn't spin either.
  • Emerson Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
Feb 01, 2011 | Samsung SMH9151 Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
I returned from summer vacation and discovered that my microwave (model MW535OW) would count down the time I set, but the turntable would not turn, nor would the microwave heat anything. Thanks!
as its been static for a few weeks and cold. whats probably happened is 'food' has set and caused the centre turning motor to cease. try cleaning the motor by removing the turnplate etc and washing in hot water. then when dry add a little not much wd40 to the moving centre.
If this helped vote for me
AndystUK
Aug 31, 2009 | Microwave Ovens
Lights up counts down and thats it no fan no spin no heating
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
Aug 13, 2009 | Zanussi ZM24ST Microwave Oven
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Oct 16, 2008 | Microwave Ovens
Emerson MW8777W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
