I have a Shaw UEI remote (no cable box), it powers the T.V.(Sony) on and off, But the channel selector doesn't function...
I have uei remote what not work whit dvd player samsung c6500t
Posted on Dec 31, 2010
We cannot change the channels
On the Shaw remote control, press the 'CBL' ("cable") button,
and then press the Channel-Up or Channel-Down buttons on the right-hand edge of the remote.
Got good batteries inside the remote control?
Oct 15, 2013 | shaw.ca
Free samsung tv hook up diagrams
If you have the "basic" Shaw Digital Terminal, use the TV's remote to set the TV to channel 3. Use the Shaw Remote Control to "channel-up" and "channel-down".
Sep 03, 2013 | Audio Players & Recorders
Remote issues with shaw cable box - volume, channel selection and power - how to sync the remote with the tv and/or shaw box/remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Jan 29, 2013 | Acer AL2671W 26 in. LCD Television
Magnavox converter box codes
There are no available codes for these, if you are using an universal remote, use the scan function. Typically when scanning you hold down setup on the remote, press SAT/Cable, then power. If it doesn't shut off the box, you press Channel up, and power again. Repeat the Ch. Up and power to keep going to the next code. When you do find the correct code the converter box will power off when you hit power. Press Enter on the remote to store that code for SAT/Cable. Enjoy
Dec 18, 2011 | Magnavox (TB100MG9) Video Converter
Vizio TV remote is in conflict with Shaw TV remote. When the TV is on, the Shaw bow and the shaw remote control would not work. I turn both systems off, then turn the box on with the remote, select a...
You need to "program" your Shaw remote to control your TV, including the volume up/down on the remote.
Mar 09, 2011 | Vizio M420VT 42 in. LCD HDTV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
