Question about Coldtech Freezers
I need to replace gaskets on the Model J36F-61S, Serial # GF61-0709-095, and I need to know the gasket profile to order the correct gasket. Can you help me with that?
  • 2,272 Answers
The model number which you gave is not proper.But the nearest model number is J3GF-61S.In your model number its J36F but actual model number is J3GF. You will have to order the part from coldtech service center :--- Contacting ColdtechPhone: (800) 314-4477
Mail:
Jimex Corporation
1575 Zephyr Avenue
Hayward, CA 94544
USA.--------------
The online link providing this parts is as follows.Click the link:-- http://www.tmeinc.biz/xcold.htm ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 09, 2010
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
Do I need to remove the bottom panel beneath the last basket of my freezer in order to see the drain tube for flushing
Hello Shirley, thank you for you post!
I understand that your Frigidaire freezer is leaking water onto the bottom panel of your freezer. This could be a possible clog within your drain line or an issue with your gasket. I would recommend performing a manual defrost on your freezer and you can do that by disconnecting power from your freezer for at least four to five hours. This will help clear out any clogs within your freezer.
You may also want to test your gasket and you can do that by using a dollar bill. Place the bill between your freezer and the freezer door. If you pull the bill and it provides resistance the gasket is good. If the bill slides out you may need to replace the gasket. It that all checks out to be in proper working order I noticed you wanted to access the drain tube. In order to access the tube you would have to remove the rear panel wall. This is not a simple DIY job and I would recommend reaching out to a professional for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Apr 14, 2015 | Frigidaire Freezers
Need Seal replaced
Carolyn,
If this is a commercial freezer we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Oct 14, 2013 | Frigidaire 12 cu. ft. / 340 liter Upright...
Chest type freezer Model # TCF1510EW00 Needs a gasket around the door. Where can I get one? Is a Whirlpool Estate chest freezer; serial # EWF1793518 with a date of 090604 stamped on the metal tag.
The part number for that gasket is 4346693 it could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Whirlpool Freezers
Need a door gasket for a 1969 coldspot chest freezer dont know model no
On all refrigerators there is an identification tag that gives the model number. Without the model number you won't be able to find the correct door gasket.
Tips for finding your unique model number
  • Look for your model sticker, tag or plate.
  • Include every digit in the model number, even if some are sized or styled differently.
  • Kenmore and Craftsman model numbers typically have three digits separated by a period.
Examples:
Jul 03, 2011 | General Freezers
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
Where can i order a door gasket for traulsen g22010
try Rick at "Restaurant Parts and More". They will need model and serial to get what you need. 1-888-814-1110. That is where I get my parts from.
Jan 13, 2011 | Traulsen Reach in Freezer - G22010
I have an old Ben Hur chest freezer that's still working good. It's so big, we put a cow and pig in it. I need to replace the gasket on the door. Any ideas?
there are several refrigeration houses that can have gaskets custom made to your spect. I would call Rick at Restaurant Parts and More and see if he can help. 1-888-814-1110.
If you have a model and serial numbers, this may also help as he does have access to some manufacturers for OEM parts.
Nov 06, 2010 | Freezers
My freezer needs new door seal . Where can I purchase one on line
depending on your exact model,
most brands and mkaes of gaskets can be ordered
www.appliancepartspros.com
type in your model number on the home search page
look at whichever door you need on the left
then look for the gasket below with the right part number
hope this help
usually ships in 24 hrs
Oct 19, 2009 | Freezers
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
81 people viewed this question
Top Coldtech Freezers Experts
Dennis Boxerman
christian nielsen
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
