Question about Hayward Max Flo 2 H.P. Pump #Sp 2815x20 115/230
What impeller does the # Sp 2815x20 use - Hayward Max Flo 2 H.P. Pump #Sp 2815x20 115/230
    President:
  • Hayward Master
  • 1,378 Answers
It uses the SPX2610C impeller. We sell it for $24.26 and have 2 in stock if you need one.
John
www.arrowpools.net
Posted on Sep 10, 2010
How many impeller fit on the pump
Impellers, vary. You can't put any impeller on a motor! Things to take into consideration for proper water movement / hydraulics, is the different parts of the volute: where the tide housed. You have the:
  • Impeller
  • Diffuser
  • Wear Ring
  • Shaft Seal
  • Seal Plate
The impeller also had to match the HP! If impeller is oversized, the motor will be over worked! If impeller is under sized, then the motor will work effortlessly, but is a waste, because it should at least be at capacity. Even if within the same manufacturer, impellers vary widely. So, find the correct impeller and use it.
Mar 13, 2015 | Pool & Spa
We have a Hayward Power-flo matrix pump SP-1510-Z1-XEHC. There is water coming out down near the end of pump near on/off switch and it kicks the pump off. We consulted a pool place they said it may be...
I WOULD SAY IT'S THE SHAFT SEAL. MAKE SURE YOU LOOK CLOSE "FLASHLIGHT TO SEE EXACTLY WERE THE WATER IS COMING FROM , THE IMPELLER MAY BE SHOT., THESE ARE A HARD PUMP TO WORK ON,. THE PARTS ARE CHEAP. BUT A REAL PAIN TO FIX, I WOULD LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY AND BEG HIM TO FIX IT FOR YOU, IF YOU CAN FIND A NEW IMPELLER FOR IT , AROUND 15 $ AND HAD THIS IN HAND FOR HIM . I THINK YOU WOULD HAVE A BETTER CHANCE, IN GETTING IT REPAIRED. I DON'T LIKE WORKING ON THESE MYSELF., PART OF THE REASON IS THAT THE IMPELLERS BREAK ,AND THIS TAKES UP MY TIME TRYING TO HUNT DOWN PARTS.. SORRY, BUT MAKE SURE YOU LOOK CLOSE "FLASHLIGHT TO SEE EXACTLY WERE THE WATER IS COMING FROM. IF I WAS OF HELP CLICK ON THE YES.. THNKX JAY
Jun 11, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
I have a SP 300 Pedestal Sump Pump that isn't pumping out the water in my crawlspace and the motor is constantly running.
I would check the input of the pump, exit and the hoses for being plugged up. The shaft of the motor may also not be connected to the pump impeller for some reason. Sometimes the impeller gets clogged with junk. Take the pump out, and clean it out first and see if that solves your problem. you can test it in a 5 gallon pail filled with water.
Mar 18, 2011 | Ridgid SP500P Black 12 Horsepower Pedestal...
Initially, I noticed water on the concrete slab which holds my Hayward SP 2807X10 pool pump and filter cartridge. I replaced all the PVC connections to ensure no leaks. Now I can see that the water is...
Thank you for posting your question here on Fixya.com.
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order. If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 12, 2011 | Hayward Sp2807x10 Max-Flo 1 Hp Swimming...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Hi we have the electrolux EW1200I and it doesnt spin when washing therefore all the clothes are soaking wet. Any help???
here could be 1 of many faults it could be the drive belt has snapped but in dryer mode if it turns then probally not, always check your filter and look at the back of filter recess to make sure nothing is tangled around pump impeller
May 20, 2010 | Electrolux EW1200i Front Load Washer /...
I had a water leak at the pump on my hot tub so I removed the motor and pump assy for repair. I removed and disassembled the wet end and determined I needed a new seal and impeller. Here's where the fun...
Here is your owners manual.
You have the correct impeller part number and the seal is a standard replacement part.
Please contact us thru www.arrowpools.net for a quote on the exact price and freight charges. Before freight, your parts would be about $20.
I can not help you with a whole wet end at this time but the parts should be available within a few days time.
Dec 04, 2009 | Home
My pump is making a "high pitched" whine . The pump has a sticker that states " Century pool/jetted motor, Serial # CA05F49034, Part-7-193262-28, Type-SP, FR-w484,HP- 1.5 SPL, 12 Amps
could be its has air getting in when its pumping or the motor bearings are worn out or just dryed out it could even be a partly blocked inlet filter causing this pump to whine,
try looking for inlet pipe air leaks and blocked filters
or some thing resting on the pump impeller
Oct 25, 2009 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Hayward Max Flo 2 H.P. Pump #Sp 2815x20 115/230 Logo
37 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
