Question about Kenmore Dryers
My kenmore model 70 electric dryer shut off after 30 minutes. started back up in little while but now wont start at all
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My dryer electric kenmore not start
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Oct 15, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Apr 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore Electric Dryer 70 Series
your motor is over heating and shutting off.you need new motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Jan 28, 2009 | Kenmore 73952 Gas Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
