Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Something between the tub - GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
  • 101 Answers
Tub has to be removed get quiliedfied service very dificult
Posted on Sep 10, 2010
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
How do you find something stuck between the tubs
Does it fill and wash, but just won't spin the clothes out? If so, you will need to replace the lid switch.
May 23, 2012 | Maytag PAV2300 Top Load Washer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
Loud during the spin cycle.
would suspect something in the drain pump rather then something witht he tub, tip unit back and check for debrisin right hand side pump
Mar 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Something caught between the Tub and asket. How do I get access?
iots only 1 trick i know..taking that this is a piece of clothes..take the bottom front panel off..ane remove the tub to pump sump hose,,that will give you a 4 to 5 inch hole to work form..try and push what ever it is towards hole...onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water gushes out dispenser
Something has gotten into the fill tube hose of the tub.  You will need to pull the drawer out and look down in the dispenser assembly to see if there is something blocking the hose.
Dec 30, 2007 | LG WM-2077C Front Load Washer
Kenmore front loader
There's no easy way of getting something out of between the tubs without removing the rubber door seal from the tub. It's a pain in the rear to get it to go back on too, because of the retaining spring that holds it in place. Are you sure the screw is between the tubs and not stuck behind one of the was tub fins? Most small items like screws will eventually find their way into the drain line and get caught in the drain pump strainer. Since you can't see the screw, it may actually be trapped behind one of the fins. One way of knowing is to roll the inner basket with one hand and listen. If you hear something rattling around it's somewhere in or on the inner tub. The outer tub (or shell) does not move. You can also look through the inner tub holes with a flashlight while turning it slowly to see if you can see anything between the wash tub and shell. Usually, water and gravity will force anything lying in the tub shell into the drain line. Let me know if this helps you.
Jul 06, 2007 | Kenmore 43142 Front Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
