My Hotpoint Aquarius Washing Machine, has stopped spinning! I'd left the washing going whilst I was out, and when I got home, noticed that all the washing was still wet, I tried emptying it, and moving the drum by hand, and it wouldn't move, with a little force (maybe foolishly?) I've got the drum to move, but it seems to be moving without the slight resistance that was present when it was working correctly? I've looked on various websites, and there seems to be mention of the belt having come off, and the wearing down of 'carbon brushes'? If this is an easy thing to mend, then I'd be most grateful to avoid any expensive repair bills?
SOURCE: Washer not completing cycle
Posted on Feb 15, 2007
  • 7 Answers
SOURCE: hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Posted on Jan 30, 2008
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
  • 32 Answers
SOURCE: Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Posted on Feb 12, 2009
SOURCE: 'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
Posted on Feb 23, 2009
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine won't spin
This site should help -
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Jan 28, 2009 | Washing Machines
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
