Question about Brother PE-150V Computerized Sewing Machine
My machine keeps saying ...check if lowr or upper thread is cut ... plz help .. worked fine before
    Genius:
  • 1,788 Answers
Totally rethread your machine, and use a new needle. Hope this is the answer for you. If not, call Brother at 1-877-276-8437 and they should be able to help, good luck
Posted on Sep 11, 2010
Upper thread always cuts. Straight stitch doesn't work. The upper thread always cuts. The tension is No. 3. The stitches is adjusted to no, 2. The fabric is thin, soft and Lacey . Please advice.
Be sure to install a brand new needle of the type suitable for the fabric you are sewing.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiJuN_Np6bMAhVJKWMKHSGmDvAQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
Use a thread that is suitable for the fabric. If you are sewing fine, light-weight fabric, use a fine thread--avoid old or bargain bin thread. Use the same upper thread in the bobbin.
When threading, always raise the presser foot so the thread will seat properly in the thread tension and verify that the thread path is correct (consult the manual).
Standard tension is usually the midway point between high & low number. The stitch length could be set a little higher than a 2--maybe a 2.25 or 2.5 for light fabric.
Since you are sewing fine fabric, it sometimes helps to use a removable stabilizer to give the fabric some extra body while stitching--perhaps a wash-away stabilizer if the fabric is washable.
Test your machine on scraps of the fabric you will be sewing. Re-adjust the tension as needed. The correct tension is when both upper and bobbin threads meet in the middle of the fabric.
If the thread continues to break, then there could be a burr or nick somewhere that is catching the thread and causing it to break. Could also be a needle/hook timing issue.
Apr 24, 2016 | Sewing Machines
Husqvarna Viking Iris sewing machine keeps beeping and top thread broke icon flashes on display despite being fine. The machine sews fine on slow speeds without issue
Does the thread actually break? The upper thread sensor is normally connected to the check spring that is part of the top thread tension assembly. I would check or have a Viking tech check the tension assembly to see if something is causing the sensor to stop working. It might be a bit of thread or something else.
Oct 22, 2014 | Husqvarna Viking 1
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
also try changing the needle
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
I keep getting message-Check if upper thread is cut- on my brother pc6000
if you checked the thread & it's fine, try turning off the machine & see if it clear the message, but if it comes back the computer part of the machine needs to be checked at a sewing machine shop
Feb 23, 2012 | Brother Sewing Machines
My Memory Craft 3500 suddenly seems to have no tension in the upper thread. Stitching looks fine on the top, but there are big thread loops on the bottom. Changing the upper tension dial doesn't seem to...
It could be a wad of lint in the upper tensioner disks keeping the disks apart. I have also seen on older machines where the thread has actually cut a groove into the disks. If you can dis-assemble the tensioner, clean and inspect. Be very careful to memorize the part order in which you remove the parts, this will help when re-assembling it.
Good Luck,
Chris
glfi.com
Feb 10, 2011 | Janome Sewing Machines
My Janome mc9700 is giving me trouble. I think it may be a tension problem, but I'm not sure: trying to get some advice before taking it to the dealer. I am in the middle of an embroidery project, and my...
1.check to see if needle is in backwards
2.the upper tension maybe to tight----check owner's manual for right tension
3.the needle may be bent--roll on flat surface to check
4.the thread maybe hanging up on the bobbin case
5.check this area for lint or fragments of old thread
6.check thread for knots, if notty replace
Jul 29, 2010 | Janome Memorycraft 9700 Computerized...
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother PE-150V Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
