Question about Texas Instruments TI-30XA Calculator
I would like to calculate pKa for 2.35. What button to push first?
3 Suggested Answers
  • 7993 Answers
SOURCE: How to find pka value
If I guessed right you are talking about the Chemistry notion of the pKa
Let the equilibrium constant be Ka =1.8x10^(-5). Then by definition pKa=-log(Ka) , log in base 10
pKa = - log(1.8x 10^(-5))
First set [MODE] to [COMP] by pressing [MODE] 1.
[LOG] [(] 1.8 [x] [SHIFT] [10 to the x] [(-)] 5 [)] . [(-)]
The [(-)] key is the change sign key : a small - between parentheses. The last [(-)] sign in the expression takes the negative of the whole calculation to obtain the correct value of the pKa.
The value you should find for the above exemple is 4.74
Hope it helps.
Posted on Sep 18, 2009
  • 7993 Answers
SOURCE: please explain which buttons to push on TI-36x
You need the [EE] key to enter powers of 10 exponents.
You need the change sign key [+/-] key.
You need the [LOG] key.
pKa: 6.5 [EE] [+/-] 5 [LOG] [+/-]
There are two change sign: The first (either before or after the exponent 5), the last is entered after you press the log key , so as to negate (make negative if result is positive, and make positive is result is negative) the value.
The result should be 4.1870866 or 4.19
Posted on Mar 08, 2010
Find an equation for a line of best fit to (2,35)(2,45)(6,70)(4,65)(8,75)
Use the Mayer line technique or the Med-Med technique. Check your statistics book for a description of the two algorithms.
Feb 19, 2014 | Office Equipment & Supplies
Can you show me how to find the ration between ph and pka?
There is not a simple ratio between these two. See: What is the relationship between PH and pKa - Wiki Answers
wiki.answers.com > Wiki Answers > Categories > Science > Chemistry
when pKa = pH, there is equal concentration of acid and its conjugate base. pKa helps to understand the nature of acid and base like pH: .... Related topics: .pka ...
Jan 28, 2014 | Personalised Grandmas Wish List Print, Not...
I need to punch in: -log 10 Ka to get pKa,how do i do that? let's say Ka = 1.75 X 10^-5 the answer = 4.76 pKa = -log 10 Ka show me step by step how to punch in. thanks!
(-) LOG 1 . 7 5 EE (-) 5 ENTER
The (-) is just to the right of the decimal point, the LOG key is in the leftmost column between the GRAPH and LN keys, the EE key is just above the 7 key.
Dec 11, 2010 | Texas Instruments TI-85 Calculator
Please explain which buttons to push on TI-36x solar calculator to find the pKa of benzoic acid. the Ka for benzoic acid is 6.5 X 10 to the -5th ? (Sorry I don't know how to type the exponents for you)
Mar 08, 2010 | Texas Instruments TI-36 X Solar Calculator
How to use the log function for acidity constants? I get a syntax error
Let Ka be the acidity constant (acid dissociation constant). The pKa is defined as the negative of the log in base 10 of the acidity constant.
pKa= - log_10(Ka) where log_10 is the logarithm in base 10.
To calculate the pKa you use the key labeled [LOG], just above [COS]. Be careful with the negative sign: For that, you use the key [(-)] just above the RCL key. Press the keys in the order specified below
pKa = [(-)] [LOG] number [ ) ] [=]
Although the right parenthesis is not required in this particular case, it is better to accustom oneself to close the parenthesis.
Hope it helps.
Dec 07, 2009 | Casio FX-115ES Scientific Calculator
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
Hope it helps.
Dec 17, 2008 | Casio FX-115MS Plus Calculator
Setting Tax rate
Push the Tax + button
Push the Rate button
Put in the rate you would like to set
Nov 17, 2007 | Canon MP-25DV Calculator
Texas Instruments TI-30XA Calculator Logo
177 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
