Question about Dishwashers
Error code e6 on new world dw60 dishwasher? - Dishwashers
5 Suggested Answers
SOURCE: new world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
Posted on Nov 01, 2007
IFIXALL
  • 868 Answers
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
  • 827 Answers
SOURCE: the new world dw60 dishwasher
either you have a plugged drain or drain filter or the water may not be hot enough in the washer. If you still have a copy of the owners manual it will also give you further solutions to this problem. If you do not have the owners manual go to the mfgr's website and download copy or call cust service...
Best regards
Ck
Posted on Feb 16, 2011
caroldon
  • 17130 Answers
SOURCE: water leaking from bottom of
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Posted on May 28, 2011
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
E5
Make sure the water inlet tap under sink is fully opened. The water pressure in mains could be lower than the setting on the dishwasher. Assuming it is DW60. See this manual.
http://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Mar 30, 2014 | Fisher and Paykel Dishwashers
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
Error code E6
Machine displays E6. Contact your local Hobart Service Office.
Jan 11, 2012 | Baumatic Dishwashers
The new world dw60 dishwasher goes through the wash programme but on completion the dishes are still not clean we do even rinse all the dishes before we put in the dishwasher but still the dishes are not...
Best regards
Ck
Feb 16, 2011 | Dishwashers
Bosch SHE44c getting a E6 code????Just finished E1 code by re-soldering the board and the first wash after fixing that error, I get an E6 code and it did not drain. During the repair of E1 code, I cleaned...
Thanks, that perfectly nailed my problem. Bad / burnt solder joint on a SHX45P05UC/57 model. A little solder, and it may last a while. But next it fails that way I can order the motherboard without even opening it up.
Aug 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
New World Integrated Dishwasher DW60 E4 flashing and beeping. Managed to get it going for a while with a d/w cleaner, it filled, water heated but then E4 error kept flashing and it stopped, had to...
Sounds like the drain pump has jammed - probably a bit of broken glass or a fruit pip, etc. isolate electricity supply, lie the machine on its back, after removing as much water as possible with a sponge etc, remove the base plate if fitted and the small drain pump should be removable, either secured with screws or just a simple 'twist' bayonet cap fixing. Check for blockages / foreign bodies in pump.
If not pump, ie you can hear it running on drain cycle, check drain hoses and plumbing for blockages. Remember there are usually two pumps, the bigger one is the wash pump. Some machines use 1 pump only, and reverse the direction of rotation for wash / drain. A foreign body in these pumps often rips all the rotor vanes of and you will need a new pump.
Feb 02, 2018 | Dishwashers
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
New World DW60 dishwasher not working originally had E4 fault Power comes into the PCB the switches and led's light up but nothing happens. After about 5 mins there is a short beep. Does not show any...
Jun 23, 2008 | Dishwashers
New world DW60-flashing lights
Oct 20, 2007 | Stoves 27 in. DW60 Built-in Dishwasher
Dishwashers Logo
178 people viewed this question
Top Dishwashers Experts
