Question about Pentax Optio S5z Digital Camera
Pentax w60 waterproof does not take photos anymore. Everything works fine just doesn't take photos. It says F3.5 in bottom left corner. Not sure if this has anything to do with it. Can anyone help please?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Driver optio w60
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 14, 2014 | Pentax Optio W60 Digital Camera
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Pentax K20D pink strip on photos
Go to the support section of the Pentax website and e-mail your question to their techs. I believe this is a known problem with a solution.
Apr 21, 2010 | Pentax K20D 14 Megapixel SLR Digital...
When I try to take a picture with my Pentax W60, it will focus but not take the picture no matter how long I hold the button
I have the same issue, no message appears - every now and again after I push & hold the shutter button (sometimes 4-5 times, 5-10 seonds) it will finally take the picture. But, again - once it focuses it doesn't take the picture when the shutter ****on is fully engaged.
Apr 10, 2010 | Pentax Optio W60 Digital Camera
Photos are black no image
CCD Failure !!
?Just call Pentax it is a known problem in thousands of cameras of different brands they will do it free of charge see the link below
Pls rate me FIXYA for help
http://www.imaging-resource.com/badccds.html
Pentax Support
http://www.pentaximaging.com/support/customer-care/
Apr 24, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Pentax option 430 camera problem
Bassie - did you resolve this? My computer recognizes the camera just fine. I have photos on my card but when I try to download to my computer, I don't see any photos. I've emailed Pentax several times w/ no help to this problem. Do you have automatic MS updates set on your machine? What Virus protection do you have? I've run into problems w/ another program conflicting w/ virus protection software.
Apr 24, 2007 | Pentax Optio 430 Digital Camera
S40 : Blurry left corner
I think the first couple of pics gets a blurry corner, and it is quite noticeable.. I hear that it was a problem with some Optio cam but not all. Maybe you could check with Pentax for a replace ? I know it quite anoying but it deserves a serious investigation. And btw, thank you for the samples, great pics. I would be really interested in seeing full size (origianl) images and some portraits. Can you post some on pbase.com ? They have 10 MEGS accounts for free.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Pentax Optio S5z Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
