Question about Kicker SX650.1 Car Audio Amplifier
As soon as i turn on my amp my fuses in the amp blow found out that there are three fried transisters so i got them fixed and its still doing the same thing
5 Suggested Answers
SOURCE: AMp keeps blowing fuses
Hey i have a RF 4004 and mine keeps doing the same thing i havent gotten the chance to open it up and see what is wrong but i do know that every time you blow a fuse you burn a little more of your amp up so quit putting new ones open it up and see if the ground and the power holders are touching
Posted on Mar 12, 2008
jerryg50
  • 1689 Answers
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
  • 631 Answers
SOURCE: When I turn on the car all 8 transisters (#IRF3205) on the 12V side of the amp blow up is their a short in side the amp?
If the power supply transistors blew out, it's possible that the output transistors have failed (shorted).
If you're going to try to repair it, there are likely 2 blown driver transistors near the driver IC (TL494). You must check them. If they're blown, the new 3205s will blow out again.
Posted on May 11, 2008
  • 7 Answers
SOURCE: How to fix my blowed amp
i would contacted jl or the dealer you got it from
Posted on Apr 20, 2010
Tail lights work fine but no brake lights. Fuse keeps blowing whenever I replace the fuse.
check wiring on shift columb going to turn signal switch it could be the switch it self I had this happen on a new chevy truck hope this helps good luck jerry
Feb 16, 2013 | 2001 Jeep Grand Cherokee
I also have a fried zd3 on my boston acoustic mcs 95 Sub amp board. Do you know the radio Shack part number you used and did your amp power up? My Sub is not working. No power and no green light but my...
zd3 is a zenna diode, you will need to find the volts that it triggers at, most amps (99%) have a mirror circuit board so all components are dobbled so this will help you find what you need Re: Jeff
Nov 25, 2012 | Radio Communications
Hello, my Mitsubishi m-vr400 was left on over night and now only 1 speaker works and I can barely hear it at half volume, did I fry the amp? Thanks
I am a retired Certified electronic technician,Of 35 years.What you can try end sometimes it will work, On the top or the side of the cover,Hit it fairly hard with your hand. If it cuts in end fades out hit it again. I have done this with amps or recievers,End probably got over 60% of them working again buy doing that. If that does not work then take the cover off off, To look if there is any fuses inside the unit, That might be blowin.If there are no fuses blowin, Then it did blow a power Transister.
Oct 27, 2012 | Audio Players & Recorders
30amp AM 2 fuse blows as soon you turn on the key & car will not start
This is common about this time on these Camrys. I own three. The AM2 fuse is blowing because a coil, capacitor, or supressor has gone bad in the distributor. To test this disconnect the two wire connectors to the distributor. Replace the AM2 fuse. Turn the ignition. If the fuse doesn't blow. The distributor.
Jul 01, 2012 | 1994 Toyota Camry
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
My mc2105 blows fuse as soon as you turn it on. this unit has been in storage nad the owner said it worked fine he lied I think but any way can you help
The Amp module might be fried, did you plug it into a speaker with an Ohms mismatch?
If the fuse keeps blowing, you need to get it repaired by a pro.
Jun 30, 2011 | Audio Players & Recorders
Blows fuse
check to see if any transisters or anything have black around it and check if any are loose on the board
Jan 03, 2010 | RCA F27442 27" TV
Ps 52 kx power supply will not hold load
thank you for your help . I have already fixed the power supply I double checked the transisters and found three bad so I replaced all the power transisters and it is fine . thanks again bob
Nov 17, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Jerry G.
Apr 25, 2008 | Car Audio & Video
http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Thanks
Feb 15, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Kicker SX650.1 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
