Question about Brookstone SongCube Digital Music Center Shelf System
I have a stereo with really thin speakers it is a bookshelf stereo where the dec opens up I got it in 2006 and it needs a new subwoofer cable as the dog cewed it up and now the stereo wont work I cant find it anywere it has a wierd end to go to the woofer and a td subwoofer input on the back of the stereo it is not a prong it has several little holes for a pug end 7 to 8 holes I cant really tell please tell me what it is as I can not find the end he ate off. I am at Help????????? I am a old ladie and dont have a lot of money.
2 Suggested Answers
  • 56 Answers
SOURCE: the volume buttons dont work
i think your wireless speaker is bad or had a factory suggestion is to return that speakers to the store if they warrant because they will replace it a new...
Posted on Dec 16, 2007
Need wiring diagram
Step 1 Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step 2 Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step 3 Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step 4 Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step 5 Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the installation
Step 1 Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step 2 Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step 3 Obtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step 4 Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
Installation Process
Step 1 Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step 2 Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
Step 3 Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
Step 4 Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step 5 Put the fuse in the fuse holder.
Step 6 Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step 7 On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step 8 In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step 9 Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step 10 Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step 11 If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step 12 Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step 13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. That's all!
Good luck.
Mar 26, 2010 | Car Audio & Video
There is a set of 4 avs 200's on Ebay for ~$200 OBO so figure around there. Really though these are 10 year old bookshelf speakers so the market for them is pretty soft especially now that Polk and the other big names have affordable bookshelf speakers... (I'm just giving my set to a friend when I move this month)
Aug 08, 2009 | Mirage AVS 200 Speaker
Subwoofer does not kick in during stereo mode with front speakers
There should be an adjustment in setup that for 2 channel sources, you may have to enable the subwoofer output. Or alternatively, if the subwoofer output for 2 channel sources is in fact enabled, then increase the crossover frequency for the sub.
May 07, 2009 | Audio Players & Recorders
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
M and K center 75 speakers need a new tweeter
depends one what size tweeter you could take one out of an old bookshelf speaker, old computer speaker, old TV, or an old boombox
Oct 19, 2008 | Miller and Kreisel Audio Players &...
Replacement speakers
You should be able to use any of the "bookshelf" speakers to replace the Front Left/Right and Rear Left/Right. I would go ahead and get a dedicated Center speaker. I bought a Pioneer center speaker and a pair of KLH 3-way bookshelf speakers at Radio Shack at low prices. I also bought a pair of Insignia 3-way bookshelf speakers. I put this all together with a Durabrand Home Theature system (dumping the satellite speakers). There is better range and a much fuller tone with these speakers versus the originals. Even if you hadn't lost the speakers, I would recommend this as a good upgrade.
Hope that helped.
Aug 12, 2008 | Durabrand HT-3915 System
Surround sound
Hope this helps,
you need to press system menu on the remote..
on the front panel display acually on the DAV unit "DEC. MODE" appears..
Press enter..
Press the up and down buttons to cycle through the options, what your looking for is "PRO LOGIC", "PLII MOVIE" and "PLII MUSIC" ..
Select one of these and this should work.
All the best
Jun 25, 2008 | Audio Players & Recorders
Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
May 29, 2008 | Recoton Advent Advent Calypso Main /...
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
35 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
