Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
I have an ariens st622 that has sat idle for over 5 years. I can`t get it to stay running unless I keep priming it. The longest run without priming has been about 3 minutes. It has new fresh gas, clean spark plug. any suggestions?
  • 97 Answers
SOURCE: starts but won't keep running
Check exhaust for carbon build up
Posted on Mar 20, 2009
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
#1 Taper
  • 1040 Answers
SOURCE: Weedeater very hard starting or not starting at all
One of two solutions. But the only thing wrong is the carburetor. It needs cleaned or it needs a new carb. kit. If you need tips on how to clean, just let me know.
Jim
Posted on May 30, 2009
  • 12 Answers
SOURCE: 17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Posted on Aug 09, 2009
  • 89 Answers
SOURCE: Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Posted on Nov 06, 2009
Testimonial: "Thanks for the help. The gas line was dessolving on the inside and getting into the carb. I replaced the gas line."
1993 5.7L. Why is it difficult to start and keep running?
Why was it left to sit? That is the first question to find out. Check compression, First thing.
Jul 30, 2015 | Chevrolet Cars & Trucks
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
My truck wont start unless i prime the carborator first, then it wont stay running unless i rev it high just before i put it in gear, or im accellerating...
To start with, you have a throttle body instead of a carburetor.
On that throttle body is a component called an air control valve.
That valve is how the computer controls the idle speed. It should open and close the air flow into the intake manifold as needed.
Is the check engine light on when you are driving ? Have you checked the fuel pressure ?
Jul 30, 2012 | Chevrolet Silverado 1500 Cars & Trucks
I have a st622 ariens walk behind What size is the string I should be using.
Your trimmer line is 18" in Length (46cm)
5/32" diameter (0.40cm). I'll give you a link to your owners manual that you can download and I hope that the link works. You may have to give some info to log into the site in order to get it; not sure, as I use the site quite often to download manuals and only had to do that the first time.
http://dl.owneriq.net/3/3f858f4f-0b60-49b5-a6f8-ec4a7a994de4.pdf
Best of luck to you.
James
Aug 11, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Bike sat for awhile, runs but doesnt idle very good. cuts out
I would remove and clean the sparkplugs - sounds like one may be fouled.
Aug 18, 2009 | 1994 Yamaha FZR 600
Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
May 04, 2009 | Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
