Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
The timer remains on all the time. I have to actually go out there and manually turn the timer off. I don't have a manual, so I don't know what the little red plastic flag amd the little black plastic flag are for. I want the timer to turn the lights on at 8:00 PM and off at 3:00 AM. Can you help me please?
  • 377 Answers
The BLACK flag is for ON time.The RED flag is for OFF time. Set the Black flag into the rotating timer for the time of day you want the timers to turn ON and the Red flag for the time you want to turn the lights OFF. Once you have the flags in rotate the timer dial by hand and note when the lights go on and off. Adjust the flags as needed. Set the timer for the correct time of day and plug in. Also, you can check the Intermatic web site for additional information.
Posted on Sep 09, 2010
Upm etw350
Copy following link to identify timer and download manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html#ETW
ETW can be used to replace 3-way switch.
3-way switching has 2 switches. Timer can replace one switch or the other switch, but not both.
The remaining 3-way switch must be rewired as shown in manual. What the remaining 3-way switch does is reverse timer programming, so programmed ON times become OFF times, and OFF times become ON times.
Add a comment as needed.
Jul 19, 2013 | UPM Programmable Wall Switch Timer
Can the timer be turned off for periods of time without losing the settings and how to ?
1) Copy following link to identify timer and download possible manual:
2) Unsure which timer you have.
Digital wall timers usually have back-up that holds memory for certain length of time before current time disappears.
Usually the programs remain indefinitely until timer is manually reset.
3) Why do you want to turn timer off?
Usually in-wall timers consume 3 watts of power per year.
Contrast big screen TV consumes 3 watts per hour standby loss when TV is turned OFF.
Feb 12, 2013 | UPM Programmable Wall Switch Timer
I don't know how to get/find/use the timer on my camera FINEPIX SL245
Press cursor-down (marked with a one-handed clock) to bring up the self-timer menu, use cursor-left/right to select the desired delay, then press the MENU/OK button. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Using the Self-Timer" section of the manual (page 39 in my copy). If you need a manual you may download a copy here.
Jan 28, 2013 | Cameras
My parafon 4001-0 is coming on at the wrong time..i have one set of trippers and they are correctly, and now have turned off the breaker to shut the lgihts off. I don't know what to do
Is the dial rotating and keeping good time?
Are the X2772 trippers worn down?
Does the manual override lever turn load on-off.
You can buy replacement trippers online.
Otherwise if the clock dial is slow, then clock motor is bad, and you need to replace timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Replace the 4001-1 120Volt timer with Intermatic T101 timer.
Crossover wiring is as follows.
Paragon terminal 1 => Intermatic 1
Paragon 2 => Intermatic 2
Paragon 3 => Intermatic A
Intermatic timers are easily repairable and adaptable for various voltages and different countries by changing clock motors
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 03, 2012 | Hardware & Accessories
My timer for sign is Intermatic T104,I Don't know
Copy following link to troubleshoot Intermatic timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Dec 20, 2011 | Hardware & Accessories
I bought a home which has the timer . But I don't know how to set the timer. Timing is now from 8 pm to 10 pm, I need to change it, how?
More information is needed about timer.
Check out following options, or add a comment any time.
Adding a comment send email and I will answer.
1) Open following link for setting analog timers.
Applies to in-wall and plug-in type analog timers.
http://waterheatertimer.org/How-to-set-timers.html
2) For a programmable timer, a comment and describe timer buttons, and include if timer is in-wall or plug-in.
3) Open following link to see Intermatic, Woods, and GE timers plug-in, in-wall, and box timers, including indoor and outdoor:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Sep 08, 2011 | Hardware & Accessories
I hope I am stating my problem clearly: I just purchased a Woods 59377 indoor timer that I'm about ready to return to the place I purchased it because of the manual override button. What I didn't...
I have 59377 timer in my office.
Here is copy of manual:
http://waterheatertimer.org/pdf/Woods-59377.pdf
What job do want the timer to do?
It sounds like you want a programmable timer at night, and simple on-off switch at day.
Add a comment if answer below misses the mark.
YES, the manual override can be used as on-off switch.
Press manual override until Manual ON or Manual OFF display.
The manual override button has 4 states:
Auto ON, turns lamp ON immediately and programming resumes at next set time.
Auto OFF, turns lamp OFF immediately and programming resumes at next set time.
Manual ON to choose permanent ON.
Manual OFF to choose permanently OFF.
Aug 26, 2011 | Woods 7 Day Digital Heavy Duty Timer...
4003-0s clock wont count does turn to show time or swicth on lights
1) If timer dial is not rotating, then the clock motor has gone bad.
New paragon clock motors are not sold anywhere I know about.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
2) If dial rotates on time, but trippers don't work, then buy new X2772 trippers.
3) Buy new 120Volt 4003-00 timer at Southside for $86:
http://www.southsidecontrol.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3823.html
4) BuildingHVAC sells 4003-00 timer for $56.00
http://www.buildinghvac.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3709.html
Aug 04, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have a raindrip 2 zone water timer...I don't know how to set it. There is no clock set, so I don't know how to program it to turn on at a certain time...
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Raindrip R673CT Digital Water Timer
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
133 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
