Question about Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum
I have a Dyson DC22 that seems to have lost a lot of suction. I can't peer right inside the wand, but it seems that hose may have disconnected from the telescoping handle allowing a huge leak. How can I take the handle apart to inspect/fix this?
  • 413 Answers
SOURCE: my dyson dc18 has no suction from beneath, but the
The head is blocked by something, it could be a bottle top, rolled up tissue, or something like that.
Take it off the end of the wand and look down the hole
'with a flashlight" where the wand goes into it..
You should be able to see it in there.
The object should be pushed out the way it went in..
Try using something made of plastic to push it out with...
Posted on Oct 23, 2009
tvservice306
  • 458 Answers
SOURCE: wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Posted on Nov 07, 2009
  • 231 Answers
SOURCE: How do you put the telescopic wand down? Just got
make sure your handle is snapped in all the way on to the machine, that will release the clip on the hose to allow for the wand to slide in.
Posted on Jan 06, 2010
Dysonteam
  • 167 Answers
SOURCE: A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
On my dyson DC22 canister the rotary brushes stop working, the suction is good. I checked the hose nothing. but a red light comes on on the start button. what to do?
Dyson don't give much help here. The wire to the head must be hidden in the hose? Can you get to where it enters the head and the body of the suction unit?
https://www.dysoncanada.ca/en-ca/support/dc22/dc22-motorhead
There are some helpful videos here though.
dyson DC22 head not spinning Google Search
Nov 21, 2016 | Dyson Vacuums
No suction when I release the wand
Hi there, it's Jack at Dyson.
If your DC28 doesn't seem to have suction through the hose, it's likely you have a blockage in the hose, wand or airway. To check for this, please follow the steps shown in our online Support guide:
http://www.dyson.com/support/dc28/dc28-animal/diagnosis-root-menu/dc28filterwashvid/wand-suction-dc28
This should resolve the issue, but if you need further help after giving this a try we're on hand to offer advice. Just give us a call 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or replacement part is needed, we can also confirm if this is covered under our 5-year warranty.
Oct 12, 2014 | Dyson Dc28 Animal Airmuscle Vacuum 00247
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson 41 has just started only sucking through the tube
We've had our DC41 for 4 months now and suddenly noticed no suction at the base as well. Base motor works fine.Thought I'd take one last look before sending in for repair. At the base of the attachment hose near the motor is a small red tab. I depressed it and pulled the entire hose off the motor. Sure enough inside was a eyeliner pencil our daughter had unknowingly vacuumed up. I couldn't see it just peering the length of the hose. Even with a flashlight. You don't see mention of the small red tab but it allows you to see close up rather than peering down the hose if something is lodged near the motor. Apparently this pencil prevented the internal hardware to switch from wand to base suction when the handle is reclined in floor vacuum mode. These vacuums have strong suction and they will pull up the oddest things! Hope this helps!!
Aug 14, 2012 | Dyson Dc 41 Ball
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
THE HOSE ON OUR DYSON ANIMAL UPRIGHT HAS LOST SUCTION-HOW DO WE CLEAN IT OUT ?
You would need to release the wand/hose assembly from the machine then slide the hose right to the bottom of the wand and press the release catch to disconnect from the wand. Then at the base of the hose you shoudl be able to un-clip the hose to remove it completely from the machine.
Full details on how to check your amchine for blockages, can be found in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 13, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kind regards
Darran
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand lost suction
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum Logo
103 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
