What would cause my computer to shut down by it self and an error comes up?
  • thielectronick
    thielectronick Sep 09, 2010
    could be a lot of things, can you read the error before it shuts down? that will give us a good starting point.
  • 6,831 Answers
Hello
If i use the information you have give, i would say you have a serious overheating problem. Have a look and see if the CPU fan is clogged with dust particles. Let me know, i will gladly assist you.
Kind regards
Andrea
Posted on Sep 09, 2010
Why I cannot shut dow computer
try holding the power button until it shuts off (5 seconds or more) if it still not shutting off than pull the plug (it's frozen), reboot the computer, if it still does the same thing than have it checked by a good technician... it could be a defective main board, CPU/GPU, a virus, the powersupply or even the power button it self...
Aug 02, 2011 | Computers & Internet
My fan has quit working. Will this cause the computer to start up then shut off after about 30 seconds?
It very well could cause that type of behavior as it is most likely reaching too high a temp and shutting down to protect it's self. A fan replacement is recommended.
Apr 04, 2011 | Computers & Internet
After turning my laptop off and traveling home, when I tried to start up again the "A" light flashes on and off (left of the power button) and then the computer shuts back down again. This may happen...
That LED error generally indicates a RAM error during the power on self test. Try reseating the memory modules. If no change try them one a t a time one slot at a time, see if any change
Mar 09, 2010 | Dell INSPIRON 6000 CENTRINO...
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue
Mar 05, 2010 | Microsoft Windows XP Professional With...
Frecquent shut downs on both computer s with vista home premium
check your ac power voltage input maybe low. chek the cpu fan. scan all your pc virus causing pc to reboot by it self.
Jun 03, 2009 | Dell Inspiron 530 Desktop Computer
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
