Question about GE 32GT720 32" TV
No picture, on/off switch does not work, and there is a constant buzzing.
  • GE Master
  • 8,457 Answers
This tv high voltage is dead.The FBT-the flyback transformer is not giving any more high voltage.The big black block of plastic,with a red wire with a cap hook to the CRT-tv tube.Analog tvs are hard to find parts these day.If u have soldering iron,solders,soldering wick or desodering pump.Can do soldering?Repair it urself?Might can find analog tv parts on Ebay.com.
Posted on Sep 09, 2010
Hi- I have a Bunker Hill security camera #47546 from Harbor freight tools. The picture works great but there is a terrible loud constant buzzing sound. What could it be?
buzzing can be from the power pack this can be amplified through the camera. sometimes a magnetic shield around the cable can stop the signal . http://www.globalsources.com/gsol/I/Choke-coil/p/sm/1034644500.htm#1034644500 they somtimes work but not a garantee, cheap power pack do cause alot of iterferace.
Jan 16, 2018 | Home Security
I have a loud buzzing noise on my Toshiba DLP 46" projection TV. It is not the fan, it works fine. In fact the TV works great and has a good picture. The buzzing used to go away after awhile. Now it...
In some cases the buzz is external. The vibration of the unit may just cause a tray, flat surface, or other surrounding attachments to rattle and buzz. Look for anything that may be loose or laying on or about the TV.
Dec 09, 2014 | Toshiba 46HM94 46" DLP Projection TV 46" -...
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Turn signal relay buzz
Relays buzz when they are not getting enough power either due to a power wire with a high resistance in it or a ground with the same problem,check the harness manually to see if you can find a loose or corroded conecter or ground point.
Nov 26, 2009 | 1990 Honda Civic
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
Dec 23, 2008 | Samsung SP-S4243 Television
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
47 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
