Microsoft Xbox 360 Console Logo
Posted on Sep 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xbox is on but the menu doesn't display on tv. All connections are fine. Is there anything I can do to fix this, or is this a repair issue?
Anonymous
Level 2:
  • Expert 225 Answers
  • Posted on Sep 10, 2010
Anonymous
Expert
Level 2:
Answers
225
Questions
0
Helped
312703
Points
567
This is mainly because the display chip has overheated if you are getting this and you can fix it at home with a top rated Xbox 360 repair guide or the option you have is to send it in and get it fixed.
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Just bought a used xbox 360. it works but the picture is like double vision...not clear. Have tried 2 different games and same thing. have checked all wires to be certain hooked up properly. Not sure what...
First, I would check the display on the TV, it may be a problem with the TV's resolution. If that doesn't fix it, then it is probably an issue with the xbox, the cords could be damaged.
2helpful
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are...
check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
2helpful
My 360 console turns on fine and looks like it is running fine but the display does not show up on the television. I have checked all the connections, unplugged it and plugged it back in multiple times...
Hi the problem you are having will lead to the red ring of death, you get the rrod when the gpu and cpu chip have over heated, as you get the sound and no picture or loss of both this says that the gpu is over heating and needs fixing.
you can try the following
1 switch the xbox off and leave it off for at least an hour
2 check all air vents are free from dust
3 make sure your not using the xbox on carpet or on top of anything like dvd or sky box
any of the above will cause it to over heat so make sure the xbox is not in a confined spaced and not on top of anything else
remove the leads from back of xbox and remove hard drive, plug all the leads back in making sure the leads are pushed in properly in the xbox and back of telly, then if you still have the problem try and borrow a friends video lead to try on your xbox.
if it still dont work then this suggests it has over heated and the damage is done so check if you have any warranty before you do anything with it, then if you have warranty take it back and get it exchanged or if your warranty it out you need to get the gpu and cpu heat sink changed and the x clamps removed and getting this done should get it working.
but you need to know that say out of every 10 i do work on only 2 wont work and would be classed as scrap, i repair these for about 25 quid plus parts which is about a fiver so your looking at roughly them prices to get it fixed, i work on the basis that if i dont fix the problem i wont charge for the work i just charge for the parts used.
let me know if you need further assistance
plz rate this solution as i have a whole page of unrated posts, thanks
Xbox 360 Screen Jumping/ Games Unplayable
Try running a dvd cleaner through it, if that doesn't work call xbox customer support, (be nice though, they will be more reseptive!).
3answers
Wont put out a picture or make sound when turned
turn off your xbox and switch the switch on the video/ audio chord and turn it back on. or just get a new audio/video cord
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
3answers
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
3helpful
2answers
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
