Question about Kenmore 24032\24036 Top Load Washer
The machine has leaked oil and will not spin.
    President:
  • 3,773 Answers
Probably oil on the clutch causing slippage
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 10, 2010
I have oil leaking on my 110 24622300 Kenmore washing machine
If oil is dripping on your washing machine, you must have something above it that is leaking. Look up to find it.
Your washing machine does not have an engine.
Jan 25, 2015 | Kenmore Washing Machines
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
The clothes are still wet after dry cycle is finished
Lift the washing machine and look underneath. Inspect the bottom of the gear case for evidence of oil. If oil is present, the oil may have leaked onto the spin clutch causing it to slip during your final spin. The transmission and clutch may need to be replaced.
Dec 19, 2010 | Washing Machines
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
Gearcase is leaking oil
What brand??? Whirlpool ,kenmores leak through the front shaft by coulpling. It will still run with low oil, it may get oil on clutch wich can make it slow spin.
Ge's old and new leak oil and can run for a long time with no oil. They will get loud and scize up after awile. Old maytags leak and keep on running. New ones drop dead.
Run yours till it dies, replace the trans with a new one or buy a new washer. There is no fix for any leaks, just replace transmission or washer.
Nov 22, 2009 | Washing Machines
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Feb 07, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer will not spin or drain water
I have a roper washing machine model RAB 2121kw and about a year ago it did the same. I was at the machine when it tried to spin one day and i opened the lid and spun the drum by hand a few times then shut the lid and slowly the drum started spinning. One problem is that i have just moved the washer and i now have an oil leak. When the drum wouldn't spin i think the motor heated the oil seal on the gear case and now it leaks. I have looked into it and don't think its that hard of a thing to change.
May 24, 2007 | Roper RAB2121KW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
