Question about Ricoh AficioSP 5100N Laser Printer
How to close fuser door on ricoh SP5100N printer
3 Suggested Answers
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
  • 903 Answers
SOURCE: ricoh aficio sp 3200sf fuser door open error
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Posted on Jun 19, 2010
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Jan 01, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Tip
What to do if your ricoh 1022/1027/270/220 copier show SC452
To who had encounted this problem:
1. Don' t panic as the copier jammed temporarily
2. Switch off the copier
3. Open the lateral door,take out the fuser unit & replace the 2 unit termistor unit with the new unit [cost around us30]
4. Insert back the fuser unit then closed the laterl door
5. You have to reset the copier, below is the process:
6. Switch on the copier
7. Push button cancel[yellow] with button 1, 0,7 then follow
on Apr 16, 2010 | Office Equipment & Supplies
Error sc545, how to solve?
sounds like you have a fuser error code to reset hit clear modes (yellow button) 1-0-7 then the clear (orange) button continue holding down until screen changes once you are in .. turn copier off.. if there is nothing wrong the problem should go away. if there is another problem with copier it will come back make sure everything is closed all doors and covers and the fuser is pushed all the way in.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Ricoh aficio sp 3200sf fuser door open error getting "fuser door open" message. opened and reclosed fuser door to make sure fuser door was closed. restarted printer. still get same message. what can i do...
Jun 16, 2010 | Ricoh Multifunctional SP 3200SF...
SC546
sc 546 is fuser fault!check the connection of fuser catridge or try this:turn on machine-enter the servicemenu-open front door-then power on/off-close front door---->this will restart your Ricoh
Apr 06, 2010 | Ricoh Aficio 1035 Copier
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Sc541 appears on the copier
Your problem in the fuser unit.Clean the fuser thermistors.To reset enter in the service mode Total clear key(yellow)-107-clear key(red) enter in the SP mode,open the front door,turn OFF the power switch and unplugged the cords.Wait 15 seconds plugged ON the power cord,close the front door and turn ON the copiers.
Nov 17, 2009 | Ricoh Office Equipment & Supplies
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
From exploere 2
Hi there have you removed the fuser unit at all? if so remove it again and to the bottom left of where the fuser goes there is a black sensor make sure that is in position.
Reinstall the fuser and shut the covers. Failing this there is a push switch that is activated when the front door and left hand door is shut. Sometimes the screw holding the cover on comes loose and causes the door pin not to reach the switch. Tighten the screw it is located behind the front door in the top left hand corner.
If that does not work then the door switch will need replacing.
Thanks J
Nov 12, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh AficioSP 5100N Laser Printer Logo
532 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
