Question about Microwave Ovens
I have a Kitchen Aid double Oven / Microwave/ Convection Oven combo plus Oven to install in our newly renovated Kitchen. It requires a new service electric line installed .The wiring calles for 8 gage copper wire 240 volts 60 Hz with a 40 AMP circuit braker, have 6 gage wire 240 volts , 60 Hz 40 AMP Circuit breaker already installed , can this oven be connected to the 6 gage wire already in the home ?? THANKS so much in advance JOE
  • usafamily4 Sep 09, 2010
    Thank you very much, you helped me out a lot.JOE
  • 3,083 Answers
Hi Joe,
Since 6 gage wire is heavier duty (thicker) than 8 gage, it will be more than sufficient to supply the oven. I'm not an electrician, per se, but have obtained permits to add wiring to additions years ago, so I know some things. The important issue is to check to make sure it meets or exceeds code, for insurance purposes, and you can verify that your wiring meets code by calling the permit people in your area, just to be safe. Any electrical contractor in your area should be able to verify this.
I think you'll be fine.
Posted on Sep 09, 2010
Installation instructions for Kitchen Aid KEMC378KSSo3
Hello, John. Hereis a link you can use to find manuals and parts list for your unit: http://bit.ly/bOwwxbI hope this information is helpful.
Sincerely, Melanie.
Apr 09, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
The power is on to my Kitchen Aid microwave convection oven, but the microwave will not heat up? Any ideas as to how I can fix this?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 03, 2011 | KitchenAid KBMS1454RSS Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
