Question about Briggs & Stratton Garden
How do I raise the height of the cutting blade on a Flymo LC400PD, Please
    President:
  • 1,851 Answers
Remove the spark plug wire - so it won't accidentally start.
Place the mower on it's side - with the OIL FILL side closest to the ground [ it should not leak oil but be sure it doesn't before allowing it to stay that way.
REMOVE the BOLTS and NUTS from EACH wheel - you will see then the other holes - then place the bolts and wheels in the hole you desire. Each hole SHOULD represent about 11 mm or 7/16ths of an inch change UP = LOWER - down from where it is originally = LONGER GRASS
Thanks
Gary @ Fix Ya
Posted on Sep 09, 2010
Testimonial: "Thank you so much. Very clear instructions. Much appreciated."
What petrol do i put in
Any 87 octane will work..but today's 10 % alcohol gases can damage some engines many are using high test 89 and up..good luck..
May 21, 2014 | Briggs & Stratton Garden
How do i lower the cut on my flymo hover 2800
remove the blade from bottom you will see many rings around the shaft of engine just place bellow or above your blade to adjust height .
Mar 11, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Won't cut on low height setting
there are several rods that support the deck if one is missing it can allow the deck to move in the wrong dirrection
May 22, 2012 | Garden
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
How do I raise the blades
there should be a big bar on the right side of the mower that changes the deck height. if it only going up a little look for a height limiter dial on the other side of the mower about where the height adjustment bar is on the right side.
good luck and be careful!
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
165 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
