Question about Avermedia AVERVISION 300AF+ PORTABLE DOCUMENT CAMERA
Light is neither red, green, or orange. It is kind of amber and does not display camera image at all.
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Samsung camera problems
when trying to power off the camera a green light which is on the right corner blinked and the images are displayed continuously. What could be the problem?
Apr 25, 2013 | Samsung ST30 Digital Camera Pink
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Dec 19, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Avermedia AVERVISION 300AF+ PORTABLE DOCUMENT CAMERA Logo
Top Avermedia Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Avermedia Office Equipment and Supply Expert? Answer questions, earn points and help others
