Error code t04-513 on riso rn2130. What does it mean and how can it be fixed?
  • jackandka357 Sep 09, 2010
    Thanks, we'll try it. I'll let you know how it works.
  • jackandka357 Sep 10, 2010
    Ok, took drum apart and cleaned sensors. Ran a few copies through, then same error message again. Any other ideas?
    President:
  • 1,566 Answers
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it. Reassemble.
To take of the drum, all around the two ends of the drum are small machine screws - you have to take the 4 out that hold the piece that clamps down the master, and remove the clamp - then all the screws around the two ends - 2 on each side have slotted holes in the drum body, so just loosen them - you need them to realign the drum body and screen when you put them back on. I kept the screen and body together when i did it. on the bottom is the big roller, covered with ink - if you look between that roller and the center of the drum, you will see the piece with two stiff wires, one short and one long - the short one needs to be cleaned completely of ink.
Posted on Sep 11, 2010
  • 3,083 Answers
My Adobe Reader is messing up, but hopefully this .pdf file of Riso's new codes will answer your question:
us.riso.com/documents/008.pdf
If this doesn't help, you will have to contact Riso Support here:
https://us.riso.com/portal/page?_pageid=777,1047495&_schema=portal&_dad=portal
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
  • 17,970 Answers
T04-513 = Ink Overflow sensor
Sometimes, the ink sensor inside the drum has two antennas, a short one a long one. The long one is always supposed to have ink on when sticking into the ink bead. If it doesn't it calls for the ink pump to turn on and draw ink from the bottle. If the short one ever gets ink on it, this error code comes up. Sometimes it is just caused by ink splattering inside.
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it, then reinstal
l to finish the job.
Hope helps.
Posted on Sep 09, 2010
Riso rz220 ui error code P02-405
Error P02-405 means: The upper-limit sensor does not go ON within 12 seconds after the elevator motor operates in the raising direction.
Jan 20, 2011 | Riso RZ220 Duplicator
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
Riso rz230 aw has error codes d-04 -534
riso mz series has error codes D04-534 and D44-538
Jan 06, 2010 | Riso RZ220 Duplicator
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
2,473 people viewed this question
jasbo
jasbo
