Question about Linksys Wireless-G WRT54G Router
Changed ISP provider and is not able to connect to internet through linksys wireless router, model # wrt160n
  • 192 Answers
Have you gone to your new ISP providers website, and surfed the internet?
I know, most routers have to be registered to gain access to the internet.
You might have to manually input the MAC address (found on the bottom of the router) to your ISP, then sometimes it takes anywhere from 5 minutes to 1 hour for the router to register, depending on your ISP.
After the router is registered, you can plug or wireless connect to the internet.
Posted on Sep 09, 2010
I just got a new modem from verizon because i switched internet providers and the internet works just fine when connected directly to my computer but when I try to use my lynksys wrt160n router I get no...
Depending from ISP it might be necessary to clone your MAC address. To do this you need to login to router settings page. You might find helpful user manual for your router: http://rapidshare.com/files/427341934/WRT160N_ug_0.pdf Start reading from chapter 3
Oct 26, 2010 | Linksys WRT160N Wireless Router
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Connecting my linksys wrt160n router from my modem using the internet port i get no connection, but if I plug the modem into the ethenet port I do get a connection, why?
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 11, 2010 | Linksys WRT160N Wireless Router
No internet connection
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Dec 11, 2009 | Linksys WRT160N Wireless Router
I can't find my linksys model wrt160n wireless router cd so i can re-install. how can I reinstall without the cd
You can reinstall the router without the CD. You don't need the CD . you can do it manually. For this you will need to connect the computer to the router and access the router set up. Once you access the router set up then you will be able to change the settings of the router. Who is your ISP, Cable or DSL ? Click Here for step by step solutions
Nov 17, 2009 | Linksys WRT160N Wireless Router
Have a acer wireless laptop I can not configurate my linksys wireless wrt610n wireless router ' I tried both options using my exsisting dsl modem and just the linksys wireless router.
your internet service provider is DSL.
Is there any other computer which is able to go online ?
If this is the only computer then you will need to check the Internet through the modem.
Your computer should be able to go online when connected to the modem.
If not online then you should have user name and password for the ISP.
if you have other computer online through the modem, then you will need to check the settings of the router.
Oct 31, 2009 | Linksys WRT160N Wireless Router
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Linksys Wireless-G WRT54G Router Logo
151 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
