Question about Frigidaire Washing Machines
The washer wont spin sounds like motor might be bad it acts like it wants to spin then it just buzzes
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, motor is bad...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 10, 2010
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
Maytag washer top load. fills with water but wont spin or agitate. makes a buzzing sound and tripped the breaker.
Motor is bad or the transmission is locked up...will need to tear apart the machine to find out exactly what part(s) have failed...
heatman101
May 23, 2011 | Washing Machines
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Oct 26, 2009 | GE WHSE5240D Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washer
Sound like you have something stuck in the pump check the hose going into from the tub
Jan 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
