Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
My irrigation system has suddenly stopped working. When I turn on the irrigation from the controller, the pump comes on like normal, but no water comes out from any of the zones. I have 5 zones but none of them come on even when selecting them manually from the controller. The timer controller and pump are both located in our garage and I have municipal water (not from a well) The pump I have is a flotec but I am unsure of the model number I have made a quick video in hopes it will help: http://www.youtube.com/watch?v=908OlBMkL3k Any help would be greatly appreciated, thanks!
MrScary66613
  • 1990 Answers
SOURCE: motor running but not pumping any water, why?
You very well could have a bunch of Sediment on the Intake for the Water OR The water table has Drpped Below the Pump.
Posted on Jan 19, 2009
  • 244 Answers
SOURCE: I want to reduce the pump cycles
put pump further down into pit if you can
Posted on Mar 14, 2009
SOURCE: Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Posted on Apr 01, 2009
  • 990 Answers
SOURCE: Flotec pump takes long time to pressure up.
This could be a problem it the pump caused by freezing, check your drain plugs first to see if their cracked or loosened. They will quite often be made if a softer nylon that will crack first and drain pump in the fation of many fail safes. A place to try on-line for parts that may help is "Optimus Home" But I would check the plugs first.
Posted on Aug 24, 2009
  • 7 Answers
SOURCE: my flotec 4/10hp waterfall/utility pump was
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Posted on Sep 27, 2009
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
When i turn the system to run hear a click in the pump relay but system does not come on
Turning the dial to run should not send any electrical current anywhere it simply is set to come on at the scheduled time. If your turning the dial to run and attempting to start the valve manually and a click the pump or valve solenoid clicks, the flow control may be closed, the water is off or the valve has failed to open. Try opening the bleeder screw to see if the valve opens this way. If so, try replacing the solenoid if no, replace the valve.
Aug 29, 2013 | Orbit Irrigation 57009 WaterMaster Pump...
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
I have a lake house with irrigation system drawing water from the lake. The pump works. But there is a second primer pump that I do not know how to turn it on or how it supposed to work.
I used to take care of a system like that in the basement of a ten story college dorm. There was a big pump and a little pump. The purpose of the little pump is to maintain pressure when there is no usage of water. Then when a big demand comes, the big pump kicks in. I had problems with the
big pump getting hot, because the controls didn't work right. I unhooked all the controls and strapped a heat sensing aquastat box to the discharge pipe. When the water got hot, this state
would open a tiny little solinoid valve and dump enough water down the floor drain to keep the
pump cool.
Nov 04, 2010 | Plumbing
Clock turns untill pump turns on then stops. does c8866 timer work with well control box?
If I understand correctly, you are controlling 240V water well pump with Intermatic C8866 Repeat timer.
So you must be using pump to irrigate, and want to turn pump on at certain times of day for short periods ... and want this schedule to repeat continually non-stop.
1) The c8866 repeats the same program every 4 hours so this is good choice for irrigation and it just turns the circuit on-and-off so it works fine with well control box (unless you want more complex programming).
Many types and prices of cycle timers
More cycle timers
Let me give a buckshot answer and see if I hit one of the targets you have.
2) C8866 according to manual:
a) You have on-off trippers
b) First ON tripper turns on load for 32-40 seconds
c) Each additional ON tripper will lengthen ON time by 30 seconds
3) To lengthen ON time: add successive ON trippers into dial. Each successive tripper adds 30 seconds. Let's say you want ON time to be 3 minutes, you need 6 successive ON trippers.
Maximum timer setting is 240 minutes, so your ON-OFF program repeats every 4 hours.
10 Tripper pins come with timer.
Buy more pins at Grainger for 2.69
4) Did you say the clock stops running after hitting the tripper? If so, maybe you need a bit of grease on the pins ... or a new clock motor? Buy clock motors at Aplus
5) Review the wiring
Hots from Breaker connect to COM and CLOCK poles
1 Hot to Load connects to NO normally open pole
Other Hot to load connects to CLOCK pole
6) You can reverse ON-OFF programming by the following:
Change Hot to Load from NO to NC pole and this will reverse on-off programming
Oct 02, 2010 | Hardware & Accessories
Irrigation system problem
How big is your pump? How much HP rating? It could be a case of blocked water line. Just check your pipe lines and the gate valve for blockage. Just your e-mail
for your comments.
Jul 04, 2009 | Plumbing
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
101 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
