Question about Roadpro RP1157A Amber Bulbs For Turn Signal Parking Lite
Replace front turn signal light bulbs in a 2000 Silverado
On top of headlight assembly there should be 2 small metal bars about the size of a pencil. Turn each one and lift both out. Then you should be able to pull entire headlamp assembly out and reach bulbs from rear.
Posted on Sep 15, 2010
  • Lisa Sep 16, 2010
    on top of headlamp assembly should be 2 small bars the size of a pencil the are L-shaped. Turn 1/4 around and lift straight up. Should be able to pull entire assembly out and reach bulbs from rear.
2001 chevy silverado horn and front turn signal failure
you need a new horn, and find the bulb that is out
Jan 17, 2013 | 2001 Chevrolet Silverado 1500
2000 Cavalier: replacing signal bulb on 99 cavalier drivers side ...
remove the mounting screw on the lens, then remove the top 2 bolts holding the headlamp, pull headlamp out to gain access to the mounting nut on the turn signal. Remove the nut and the turn signal light will pull straight out allowing you to replace the bulb.
May 17, 2010 | 2000 Chevrolet Cavalier
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Fog/Driving Light Bulb Size: 880
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 558
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168
Dome Light Bulb Size: 562
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Thank you for using fixya.
Apr 30, 2010 | 2000 Pontiac Montana
How to repair turn signal,stoplight for a 1993 Chevrolet silverado
ck test light to see if u have power,,then replace tail light bulb assembly,,
Feb 01, 2010 | 2000 Chevrolet Silverado
2000 sunbird front turn signal bulb
only i could replace mine where to remove clips from the black wheel well cover then the light bulb un screws from the back of the lens
Apr 07, 2009 | 2000 Pontiac Sunfire
Marker light working but turn signal not blinking
make sure the bulb is grounded good . usually if the front one is lit and the signal is fast the rear bulb might be bad . turn on the side that is not working properly and take off the lense and wiggle the bulb. also you might have to gt under it and check for the ground for the bulb .. holler if ou need more Jerry
Feb 05, 2009 | 2000 Oldsmobile Intrigue
Front right turn signal
i had a bad socket that was my problem on mine.
Dec 10, 2008 | 2000 Oldsmobile Intrigue
Stereo light bulb replacement.
deep inside head unit at front is the led to replace .. likely soldered into a board there as a non replaceable part ..remove head unit ..disassemble to get behind front panel...good luck..maybe this is not a worthwhile project money/ time wise.... my 2 cents
Oct 27, 2008 | 2000 Chevrolet Silverado
2000 Accord turn signal problem
either the front or the rear turn signal bulb is blown, that is why the flash frequency is high. replace the bulb and the problem will be solved. best to replace both the front and rear turn signal bulbs. good luck.
Aug 29, 2008 | 2000 Honda Accord
Roadpro RP1157A Amber Bulbs For Turn Signal Parking Lite Logo
641 people viewed this question
Top RoadPro Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a RoadPro Vehicle Part and Accessory Expert? Answer questions, earn points and help others
