Question about Samsung LE32A457 32 in. LCD TV
Turn hdmi2 on - Samsung LE32A457 32 in. LCD TV
  • 505 Answers
Hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Posted on Sep 09, 2010
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
ARE the HDMI Inputs on my UHD Sinotec STL 40E 6000M HDMI2 compliant?
I also don't know about this sorry Bro
Welcome to your brand new free ROBUX.
Unilimited FreeRobux on about me
Dec 07, 2017 | Computers & Internet
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Aug 16, 2016 | Televison & Video
Cable is connected to HDMI1. When Tv is turned on, the screen is corrupted/distorted. Color is messed up, wavy vertical lines, from middle of the screen down. But there is sound. What is wrong/ how can we...
Try first by using another port. Select HDMI2 and select proper "Input" from remote. If you get the same results, cheap HDMI cable. Replace it. If it is only on HDMI1, then there is a problem with the contacts. Warranty or just use HDMI2, 3 or 4 etc. Worse case senerio, you can use the 5 cable component cables as they can also carry HD signals.
Jun 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Can't see or listen to stb when changing input source and go back
Maybe the STB detects that there is nothing "listening" on the other end of HDMI and turns its output off. Does it work again if you turn off+on the STB without touching receiver?
Jan 18, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Samsung LE32A457 32 in. LCD TV Logo
313 people viewed this question
Jerry Greenberg
Jerry Greenberg
