Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE SxS that sounds like it is running all the time. The freezer appears to be fine, but the fridge is not cooling like usual. In fact, we have change the temp settings to make it cooler and even after a whole day the milk seems a tad warm. What can I do to defer a repair person or know that it is time to call one?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Freezer is fine. fridge side does not get cold
Samsung sxs refrigerators usually have a dual cooling system. That's why the freezer works fine. Refrigerator side could have a clogged drain or a defrost problem.
Feb 14, 2015 | Samsung RS265LBBP Side by Side...
I have A LG SXS Fridge. The Freezer is fine the fridge is not cold. I have read that the damper door might be closed. How do I find the damper door?
The damper is between the fridge and freezer section.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
The freezer appears to be working fine, however the fridge is not cold at all. For the last week it has been getting warmer and warmer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | GE Refrigerators
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
GE Bottom Freezer Refrig
i assume this is a frost free type with air drive from freezer to fridge to cool fridge.
if so, take back plate off inside freezer and you may find ice build up especially towards the top of the coils. melt off with a hairdryer carefully. the nother thing that may happen is that the return duct for air from the fridge may also become blocked with ice. this is more difficult as it is usually hidden behind the coils and the best bet in this case is to switch off for 24hrs with the door open
Oct 06, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
